Does your boat have a handedness?? (preferred tack)
Posted: Sat Jul 13, 2013 9:37 pm
The strangest thing happened sailing today.
I headed out in maybe a 5 knot breeze coming from ESE (120 degrees) with 1/2 meter waves, also coming from ESE (diagram at bottom of post).
I was on a port tack, heading at about WSW (210d), but I was making barely more than 1 knot. I should have been able to pull 2-3 knots easy, so I checked everything twice - rudders, motor, centreboard, genoa ticklers, mainsheet ticklers, shroud telltales, windvane. Everything seemed right, yet it felt like I was just dragging an anchor. There was plenty of wind - for a Mac.
I played with point-of-sail and sail trim for over two hours, back and forth between beam reach and close haul trying to find the wind. Never got over 1.2 knots. I was adjusting the wheel constantly to keep from luffing or falling off.
So I decided to tack. I came about to NNE (30d) and immediately picked up to 4 then 4.5 knots and stayed steady on course.
Sails set to same trim as on port tack. Covered the same ground back to my start point in about a half hour.
Tacked back again and dropped back to 1.5 knots (to be fair, it was late afternoon by then, and the wind had dropped noticeably).
I cannot explain it. My theories in descending order of likeliness:
- I sucked at trimming today? On the port tack I just have been way over on a beam reach but set for a close haul. (Don't know how this is possible, I played with PoS and trim for two hours).
- I sucked at trimming today - take 2? Why is my no-sail zone 180 degrees wide? I couldn't seem to point up. Even though I was trying to get to a close reach, my PoS was actually more of a beam reach.
- wave action? (at first, I thought I was going into the waves on the outward leg, but with it on the way in, but I was pretty much broadside on both legs).
- dragging something in the water? Nope, before you ask, my bumpers were hanging - but they were actually on the PORT rail, so it should have had the opposite effect.
- a strong eastward current? A 3 knot current would actually accomplish the very thing I observed (But it's not like Lake Ontario suddenly decides to have a current ...except ... we did just have a record-smashing rainfall, and water levels were up by a foot hmmm...
- my SeaSaw just likes being on a Starboard tack...
There were a couple of things that were odd about today's sail that might be clues.
1] My wind signals were acting weird. Shroud telltales said close reach, but wind vane said beam reach. (Remember, if either one was lying, it shouldn't have caused the problem, since I ignored them when I hunted between beam reach and close haul). I wondered if there were some thing to do with water temp versus air temp.
2] Not sure why, in a light wind, my no-sail zone was 180 degrees wide.
3] On the port tack, (doing 1 knot), she would absolutely NOT stay on a course. How can a boat round up in a 5 knot wind!!! I'm not talking about finding the wind; I'm talking about the boat would just drift off course, rounding up or falling off constantly.
(sorry this is upside down. I set out southward from port)
