Outboard Gas Tank Question
Posted: Tue May 27, 2014 6:53 am
I have been wondering about something for a while and really can't find any information on it.
I have a Honda 8 HP outboard on my 26S which is always connected to the gas tank. When finished sailing for the day, I always close the vent on the tank to keep the fumes contained and prevent condensation from the heating and cooling it goes through every day. The question is - what is all that increased pressure doing to the carb? Can I assume that, with the motor tilted up, that increased pressure doesn't shove more gas into the carb? Is the needle / float valve really that good at keeping all that pressure in check?
What do you recommend: Vent open, vent closed, or vent closed but hose disconnected?
Thanks!!
Thanks!!
