Mac26S lightning protection
Posted: Mon Jun 02, 2014 10:38 am
I am a new owner of a 1991 26S. I live in the Tampa bay area and will sail the boat a lot in central Florida, in salt water and fresh, basically right in the middle of the lightning capital. I am concerned that the boat has no grounding from the mast or shrouds to the water.
There is a lot of good discussion on this now 4 year old thread:
http://www.macgregorsailors.com/forum/v ... =lightning
But there does not seem to be a lot of consensus.
It seems that there are two approaches to protecting a boat from lighting:
* Provide a ground from the mast to the water. This ground may attract lightning but will safely conduct it to the water. Unfortunately, it must be very robust to handle the current of lightning and is therefore not very feasible for a trailer sailor such as a 26S or 26D.
* Isolate the mast and shrouds from the water to reduce likelihood of strike. Whether this actually reduces risk seem to depend on who you ask. Those who advocate an advantage say that a grounded mast will allow for the water to build a charge in your rigging, attracting a bolt. They point to the rarity of strikes to cars, which sit on rubber, vs the commonality of strikes to farm equipment, which are often connected to steel appurtenances such as plows that are in contact with the earth.
When I was a teen, I was sailing a regatta in Lasers in Sarasota. There was a storm approaching, but the race committee wasn't cancelling. Finally, people just started heading in quickly. Coach boats were towing sailors in as quickly as possible. A laser is a single person boat, unshrouded. The hull and deck are sealed together airtight making a hollow void. The mast sits down into a tubular step that goes through the deck down to the hull. The lower end of the aluminum mast is separated from the water by a plastic cap and maybe 1/8" of fiberglass.
A girl on our team was in tow, sitting in her cockpit, when lightning struck the top of her laser mast. The electricity went down her mast and then bypassed the plastic cap at the bottom. It went through the air space between the hull and deck, and made a couple of small holes in her hull. Unfortunately, her boat was older, and a little bit leaky. The water in the hull was heated by the electricity and turned to steam. The pressure inside the boat was enough to blow the boat up. The deck blew apart from the hull upward at the bow and stern. Floatation bags flew. Sitting in the middle of the cockpit, the skipper was unharmed, et confused as to why her boat exploded. If she had been touching her boom, however, she may have been hurt.
The 26S or 26D is similar. Its mast and shrouds are isolated from the water, which might make strikes less likely, but what happens when a strike does occur?
I'm mostly of the opinion that isolating the mast will not significantly decrease a strike risk. Disclaimer: I am a mechanical engineer, not electrical. Here's my logic. Electricity follows the path of least resistance. Let's say that there is a cloud at 150 feet above the water. That's 150ft of air with high resistance, a little bit too much resistance for the charge to break through. It's basically a big capacitor. Along comes a standard 26S. It's shrouds and stay go from 3 ft to 33ft, so offer 30 ft of very low resistance. Now the lighting only has to travel through 120ft of highly resistant air and 30 feet of low resistance stainless steel and aluminum. If the boat were well grounded, it would be 33 ft instead of 30. If the charge between the cloud and the sky was just shy of breaking the 150 ft jump, It may now be able to break the 120 foot jump, and there isn't a huge difference between the isolated boat which offs 30 feet of low resistance travel to the grounded boat that offers 33 ft of low resistance travel.
Here is my proposed solution. Build a safe path for lightening to travel down to the water, put provide an electrical break in the path, a break short enough to allow for a high voltage strike, but large enough to prevent charge buildup that might attract a strike.
Basically, run a large wire or stainless strap down to the rudder head and/or a copper plate in the water. Perhaps the copper plate could wrap around the leading edge of the rudder, doubling as a protector from logs. At the top of this wire is a stainless steel plate that is held at a distance of let's say 1 inch away from another stainless plate, in parallel, which is bolted to the backstay plate. It's not a new concept. The two parallel plates is a lightning arrestor, similar to those used in communications equipment and electric fences.
In this case, the electricity has 32 feet, 11 inches of travel along low resistance metal at the backstay, but has 30 feet at the shrouds and backstay. At the mast, is has about 29 feet of aluminum and 4 feet of wood at the compression post. My theory is that if lighting strikes the top of the mast with this design, then nearly all of the electricity will go along the back stay, jump the 1" gap, and down the 3' conductor into the water. Very little current should pass through the shrouds and forestay because of the resistance of the 3' air gap or the mast because of the 4' wood gap.
Who thinks I'm brilliant? Who thinks I'm paranoid and overthinking? Who thinks I'm an idiot?
