What Size Ball - Mac26M
macsailor65
Post by macsailor65 »
I recently purchased a 2006 M26 and have a question on towing. The manual said to use a 2 inch ball on the tow vehicle. My 2 inch ball would not fit so I used a 1 7/8 inch ball. Am I required to use a 2 inch ball? It did not fit. Any ideas?
Y.B.Normal
Re: What Size Ball - Mac26M
Post by Y.B.Normal »
I offer 3 suggestions:
1. Look on the coupler itself; it should have stamped on it if it's 1 7/8", 2", or larger. If you use a smaller ball than what's required, you're taking the chance that it may come off the ball. It's no fun chasing the trailer after it leaves the ball. USUALLY :) the safety chains keep it behind the vehicle.
2. Make sure the coupler ball socket is opening up all the way. I've had this happen on several hitches; the moveable piece inside the coupler may be jammed or sticking. Lubing it or prying it with a screwdriver gently should loosen it.
3. Make sure the ball isn't egg-shaped. Severe pressures may have deformed the ball. It it is, replace the ball.
Hope these ideas help.
1 7/8" balls usually are only good to 2000 lb. The :macm: and trailer will be 4000 lb or more and came with a surge brake coupler for a 2" ball. Unless someone changed the coupler.
What YBN said.
Stevenhigbee
Post by Stevenhigbee »
When I bought my 26S and went to pick it up, it wouldn't attach to the 2" ball on my truck either. The ball on my truck had a rounded top, and it needed a flat top.
