Removing the plastic covers at top of center support on M26X
Posted: Sun Dec 21, 2014 9:13 pm
by bobherk
Hi, I need to get to the mast wiring at the top of the center support/keel cable guide on my 1997 Mac 26X. There is a split black plastic cover around the support pole at the cabin top. How do I remove that cover? Do I pry the halfs off or is it attached some other way? Thanks for the help, Bob
Re: Removing the plastic covers at top of center support on
Posted: Mon Dec 22, 2014 6:54 am
by Tony E
Hi Bob, I have a 98X and last summer I wanted to get those black plastic caps off so I could take a look inside. Mine were just siliconed or glued on and yes split in half. Be careful when prying them up but they come off with no problem. Afterwards I just cleaned them up and put some new silicone on them and put them back on. I hope this helps:)
Tony :macx:
Posted: Mon Dec 22, 2014 8:01 am
by bobherk
Thanks Tony. This helps a lot. I just didn't want to break anything internally as I was pulling them off. Now I know I won't. :D
Posted: Mon Dec 22, 2014 8:26 am
by tp56ihs
I have a 1996 26x and found the same mounting technique. Just pried it off gently and was fine.
Posted: Mon Dec 22, 2014 8:35 am
by bobherk
Thanks again for support. Much appreciated! Bob
