What is this wooden tiller-lookin thang?
Posted: Mon Jun 22, 2015 5:44 pm
by Loala
Hi!
Just picked up an '88 26D and this thing was under the setee.
Can anyone help me understand what it is used for?
It is hook-like on the end and it appears it has a cut-out for a round ball-like item to leverage on more toward the middle.
Re: What is this wooden tiller-lookin thang?
Posted: Mon Jun 22, 2015 7:16 pm
by kmclemore
Not sure... perhaps a boom crutch?
Posted: Mon Jun 22, 2015 7:55 pm
Looks like a dowsing rod or maybe a henway.
Posted: Mon Jun 22, 2015 10:32 pm
by seahouse
What does your tiller look like? Could it be an extension or back-up for it? Or a prop rod to hold the engine tilted while trailering?
Posted: Mon Jun 22, 2015 11:01 pm
by Wind Chime
RussMT wrote:Looks like a dowsing rod or maybe a henway.
... what's a hen way?
Posted: Tue Jun 23, 2015 8:20 am
by Max Entropy
2 - 3 lbs ?
Posted: Tue Jun 23, 2015 6:10 pm
by sailboatmike
Im thinking tucked away under a bunk may be a clue as its not used much, maybe some sort of gin pole for mast raising
Posted: Tue Jun 23, 2015 7:00 pm
by cptron
2 - 3 lbs ?
I'm a USDA inspector at a chicken plant and the hens weigh 8-10 lbs.
Posted: Tue Jun 23, 2015 7:36 pm
by vizwhiz
Table leg for holding up the swing-up wood table?
Posted: Tue Jun 23, 2015 7:45 pm
by vizwhiz
Something used for leverage to pull up...
A round ball on a rope, think crab trap bouy, and you clip the other end under something, maybe to lift the dagger board? Or to raise a bucket out of the cabin? Or used to tilt the outboard? (I'm thinking that might be it...)
Or, vice-versa, maybe used to pull down the furler/forestay to pin it by holding the drum in the round part and hooking the clip ends under something to push down on the handle end and force it down?
EDIT: Could have been used to help pull-start the outboard...
EDIT EDIT: it's weathered on one side, so that side may have been exposed to the sun. (Or to bilge water)
Posted: Tue Jun 23, 2015 8:31 pm
by Billy
I would agree with the lever idea of pulling the furler drum down for pinning. The double notches would fit on each side of the single forward cleat. Then one could lay a ss rod or heavy screwdriver over the notches and under the cleat. This would give the leverage one would need to pin the forestay alone. Distance between the notches and the round cutout looks about right for the job. Pretty smart if that is its purpose. I like it.
Posted: Tue Jun 23, 2015 9:53 pm
2 - 3 lbs ?
There's a pullet in every pen that's mightier than the sword....
Posted: Wed Jun 24, 2015 5:56 pm
by BOAT
chinook might know - he has a ball thing on his boat. It looks like it fits on a ball thing like in this picture from chinook:
Posted: Thu Jun 25, 2015 9:31 pm
by Johnacuda
Arrrggghhh, Peg leg matey.
Posted: Fri Jun 26, 2015 10:09 am
by walt
I also think its a furler pinning lever (err.. does this boat have a furler??)
I can see the two fork ends being inserted over the top of the furler drum from the front of the boat. The "round indent" would fit over the fuler drum and then maybe a loop in a rope (or???) farther back on the deck loops around those two notches on the fork end.
Then from the front of the boat, you could pull down on the single stick end and pull the fuler into place to be pinned. If the back loop (or however its attached) is placed right, it would put the furler tang right in place for pinning.
I just did something similar (posted earlier) and I think as long as the wood doesnt bust, that could work nicely. Assuming that this is for pinning a furler..
