Custom Inclinometer
DHK79
Custom Inclinometer
Post by DHK79 »
Hey guys,
I've gotten a quote to have some Inclinometers custom made for use on Macs.
Here are the specs:
Inclinometer: AXIS: single; DEGREE RANGE: ±26º in 2º increments; CASE:
Welded Polycarbonate; MARKINGS: white on black background.
COLOR ZONES:
Green = ±15º
Red = 15 to 26º (±) Note: This range selected as the nominal limits for best performance for the hull and not to indicate you are over too far.
The cost is $51 (US) + Postage & Handling (1st class postage from me to you). The minimum order for custom units is ten (10), so if you're interested comment on this thread for tracking and coordination purposes. If we get enough people interested, I'll be glad to handle the order and distribution.
Doug (DHK79) :macx:
DaveC426913
Re: Custom Inclinometer
Post by DaveC426913 »
Is that photo an example? It's not the prototype, right? Because the markings don't match the specs.
yukonbob
Post by yukonbob »
I think I paid less than ten bucks or mine form West marine or somewhere else and it goes to 45-50 degrees cause its bound to happen, intentionally or unintentionally
Does it have a range for "Whooooooaaah!" when the admiral starts to scream.
DHK79
Post by DHK79 »
DaveC426913 wrote:Is that photo an example? It's not the prototype, right? Because the markings don't match the specs.
Correct. The photo is the stock model, without the custom markings.
DHK79
Post by DHK79 »
yukonbob wrote:I think I paid less than ten bucks or mine form West marine or somewhere else and it goes to 45-50 degrees cause its bound to happen, intentionally or unintentionally
Understood, but not what I'm primarily interested in. If it goes that far, you can be sure that the inclinometer will not be what I'm looking at. So I'd rather have a more accurate gauge for the lower end, although I am contemplating the use of a second high scale one mounted elsewhere.
LOL
So that's a marking for "oops", another one for "Whooooooaaah!", and one for "Oh wow" :D
RussMT wrote:Does it have a range for "Whooooooaaah!" when the admiral starts to scream.
yukonbob
Post by yukonbob »
I've been on the lookout for one that goes past 50...should read 'whoaa!!" 30-40 color coded red / "WTF" 45-50 color coded yellow and Holy Sh*t!!!" for 55 + color coded brown :P
+65 coded Yellow for u r now submerged "Yellow Submarine" :D :D :D :o
DHK79
Post by DHK79 »
Just for you yukonbob, I'd recommend a port & starboard pair of these:
You'll have to add your own color coding though. :D
Lee Ward
Post by Lee Ward »
Inclinometer.
DaveC426913
Mine still works perfectly for me.
I admit, yours is a classic. :D
DaveC426913 wrote:Mine still works perfectly for me.
yukonbob
Post by yukonbob »
dlandersson wrote:I admit, yours is a classic. :D
:D :D :D
DHK79 wrote:Just for you yukonbob, I'd recommend a port & starboard pair of these:
What only 80 degrees? :D :D
budgates
Sailboat: MacGregor 26D
Post by budgates »
:D[/quote] What only 80 degrees? :D :D[/quote]
What is the "point of no return" for a Mac anyhow? I'd guess somewhere between 110 and 130.
