Replacing dagger board fixed block and line
Posted: Mon Oct 05, 2015 5:37 pm
by mallen7
Ahoy mates!
I need to replace the cheek block for my dagger board. Does anyone have any advice on how to go about this? The block appears to have two screws that go into the deck. Do I need access from under the deck to change it out? Also, I would rather not make any new holes in the deck. Where would I go to find a direct replacement (or an upgrade block with the same fastening points?)
I also am replacing the lines for my dagger board and rudder. I'm not sure if the ones on my boat right now are original and would like your opinion/recommendation on the Best type and size of rope to use.
Re: Replacing dagger board fixed block and line
Posted: Tue Oct 06, 2015 9:32 am
by budgates
Yes, the block is through-bolted. Mine was also glued in place. Access to the nuts are fairly easy if that part of the boat is stock. Above the sink, next to the daggerboard trunk, should be a plastic panel held in place with two screws. Remove those two screws and pull out the foam and you have all the access you need.
Finding an exact replacement may be the hard part. You'll have to contact a supplier who is willing to take the time to work with you and give them the distance between the holes.
5/16 double braid polyester line works well.
Posted: Tue Oct 06, 2015 11:27 am
by Paul S
there is a harken cheek block that is a perfect fit. Measure the holes and look it up.
Posted: Thu Oct 08, 2015 8:42 am
by mallen7
Okay, here's an update that I hope will help others in the future. Bluewater yachts carries them. I ordered three because apparently the same block is used at the top of the mast and on the rudder. They are $10 each.
"Access to the nuts are fairly easy if that part of the boat is stock. Above the sink, next to the daggerboard trunk, should be a plastic panel held in place with two screws. Remove those two screws and pull out the foam and you have all the access you need." thank you for the advice. When I removed the plastic panel, the foam was broken into many many pieces. Apparently the previous owner had removed the foam to install the radio. I wonder what the purpose of the foam is? What is the downside of leaving the foam out?
I am replacing my jib lines so I think I will use the replaced jib sheets for the dagger board line.
Thank you for the above advice and help.
Posted: Thu Oct 08, 2015 3:52 pm
by cptron
These boats are known for their capacity to not sink to the bottom if holed due to the positive flotation placed throughout the boat. Hence you should not remove the foam from the compartments if you want to stay above water in the event of a sinking. Just Google mac26 and watch the video and you will see what I mean.
