ian wrote:. . . only suitable for within 1km of coast - obviously realise it is a trailer sailer and not a blue water sailer . . .
The 26X will actually take quite a beating, more than I care to subject myself to on any regular basis. And I speak from experience, as can many others here.
But it's true that it's a coastal cruiser, not a blue water boat. If you want blue water capable (as in, the intended use), there are trailer boats out there, but you'll pay waaaaay more money for one, and it will be waaaaay heavier to tow. Here's a Nor'Sea 27 being launched, from its 3-axle trailer (the Mac OEM trailer has a single 3500 lb axle).
https://www.youtube.com/watch?v=5_fu44SFNVE
It's listed displacement is 8100 lb (it has a 2-cylinder diesel inboard, too), but that's before putting your personal kit on board. And all the other stuff. Like maybe filling the water and fuel tanks all the way. Should be well over 10,000 lb with trailer and supplies. List price new is around $150k, but used ones from the 70's are around $30k or so.
http://www.norseayachts.com/norsea27.php
And look at the hull shape. Not designed to go fast, but definitely designed to handle conditions that most people would rather not sail in. Should be good in a following sea, too.
Oh, and you can pull a tube with it, but only at hull speed, if that fast. But it sure is a sweet looking boat.
My point being that the Mac motor-sailors were designed to do a combination of things almost no other boats do, at a low enough price point that many folks can afford to play, and light enough that they don't need a heavy pickup truck to haul it, while being able to float on/off (the Nor'Sea needs to be winched, by the way, but at least it doesn't need to be crane launched/hauled). Of course there are compromises. If there weren't, it would look like the Nor'Sea or some of the other, far heavier, far more costly boats, most of which can't go fast.
p.s. Take a lesson from the guy in the video with the bow line, who panicked and tried to tie it off to a rail. Know in advance what's going to happen, and what you're going to do when it does, and when it starts running away like that, just put a steady pull on the line and it
will slow and stop unless there's a strong current pulling it away from you. Good thing the lady with the stern line didn't let that one go, or someone would be swimming after it.
