Furling Main
Furling Main
We got a Mac26M with a roller furler for the main. I can't find any instructions on how it the furling line should be led to allow it to furl. Happy to send a photo but don't know 1) which direction it should furl, and 2) how the line that goes through the boom should be connected to the turning spindle and 3) if the foot of the sail should be cleted to the hardware or just tied to the end of the line that furls. I welcome any help.
confluence
Re: Furling Main
I have been thinking of investing in one ,or building a fuller
ANY ideas??
confluence
ANY ideas??
confluence
- yukonbob
Re: Furling Main
You'd think the furling line would spool onto the drum as you raise the sail with the main halyard. Those blocks attached to the boom may be for something else as it wouldn't make sense to direct the furling line forward away from the cockpit? Maybe one block them to a cam cleat or something? Maybe a pic of the whole boom both sides showing most or all hardware?
- Jimmyt
Re: Furling Main
It does wind the furling line onto the drum as you raise the sail.
The furling line leads forward to the mast, so it can then drop to a deck turning block and be led back to the cockpit. The PO put the cam-cleat on the boom, in lieu of on deck at the cockpit for some reason. I just haven't changed it yet. Still trying to figure out all of the things I want to change before I start drilling fiberglass. I like the infinite reefing, but there are some design compromises that I'm not crazy about.
KootsChewt
- Location: Kootenay Lake, Nelson, BC, Canada [2008 26M, 20hp Merc 4-str, bought Sep '16, Mountain Bluebird]
Re: Furling Main
TheJimmyt wrote:It does wind the furling line onto the drum as you raise the sail.
Anyways, we are looking for assistance on how to make this process easier, as so far we are finding it pretty annoying to drop the sail. So far we've picked up from the forums that we need to be pulling on the leach while rolling, but I don't think we'll be able to do that unless we run the halyard back to the cockpit through some blocks. I may as well run the furling line through blocks and guides to the cockpit as well and move the cam-cleat off the mast.
Any other thoughts on how to operate this set-up successfully?
- Jimmyt
Re: Furling Main
I can stand at the front of the cockpit and work the halyard cam cleat and the furling line. The sail tends to move forward on the drum as you bring it down - occasionally binding. If you tug on it as it comes down, you can keep it rolling ok - just pause and pull the sail aft on the drum a few times as you bring it down. Ideally, it would have come with an auxiliary track that attaches to the mast so the bolt rope was properly aligned with the track. I bought a can of sailkote for the track and bolt rope, but have not yet tried it (working too much right now). My problem is binding while raising the main - I've had pretty good luck dousing it. Lazy jack and slides might be easier to deal with - though reefing won't be quite as convenient or as variable. I'm still trying to figure out whether to debug it or change... if I have an epiphany, I'll let you know. Good luck.
KootsChewt
Re: Furling Main
Jimmyt, my mast track currently does not have any kind of feeder, so I think that's why the previous owner left the halyard at the mast, so he could feed the sail into the track. The PO did buy a sail feeder, though didn't install it, so I plan to install it next spring. (http://ca.binnacle.com/p3266/SPINLOCK-R ... _info.html)
Once I've got that on, I'll see if the raising process is any better, and I'm hoping the tugging on the leech will help the dousing side of things. If we get that sorted, I'll run the lines aft and call it a day. I do like the idea of the furling main (esp. since my sail only has one reef point), but only if I can get it functional.
KootsChewt
Re: Furling Main
Oh you already have one and it is binding when raising? Bummer, I was hoping it would feed it right in. Well it probably still works better than what I have to do now. Yes I would love a photo whenever you get a chance.Jimmyt wrote:I've got a binnacle. Let me know if you need a pic of where mine is mounted.
Estate Sail
Re: Furling Main
I have a roller furler main that gave me trouble binding while raising it. I tried sailcote without much difference. I finally measured the thickness of the sail fabric just inside the bolt rope and adjusted the channel guide to just slightly wider than the sail thickness. Since doing this the sail goes up without binding. Before doing this, you could see how the bolt rope was getting caught in the mast channel adjuster. Once it was properly adjusted, I drilled a third hole in the adjuster bracket to ensure it would not slip.
- Jimmyt
Re: Furling Main
Estate Sail,
Do you have picture of your setup? Is it different from mine? Sounds like you have it dialed in - congrats!
KootsChewt
Re: Furling Main
My furling main sail has a full batten at the top, two partial battens, and then another full batten just below the original reef point (at about 6' from the foot). Is that full batten necessary for the furler? Can I get rid of it and go back to a partial batten? I've got some pics at home I can upload if that is helpful.
Estate Sail
Re: Furling Main
Jimmyt,
Here are pictures of how I solved the jamming main while raising my main roller curler. The fabric thickness inside the bolt rope is 0.120 inches. I set the mast guide at 0.150 inches. I secured the guide so it won't move with a third screw.file:///Users/rogerpatry/Desktop/sail%20guide/DSCN0271%DSCN0274.DSCN0277.JPG
