Loose or tight?
Posted: Wed Aug 17, 2016 1:13 pm
Hi,
Changing the keel cable on the V25. Simple 1/2 hour job.....Wrong! PO had plastered 3/16" of bottom paint over the hardware. Lesson learned, DON'T DO THAT! Hardware was installed so tight it crushed the cable eye thimble. Now my thoughts and question:
One would think you would want the thimble to rotate as the keel travels thru it's ark as it is moving up or down, so should it only be tight enough to have that happen to avoid the kinking at the crimp, or should it be stupid tight like it was?
T
T
