There was a very thin black coat on top of blue coat on top of the gelcoat. The black paint was mostly gone, and what remained came off with the growth when I used the power washer.
So to prep for painting, what do you recommend? Do I need to sand the blue off down to the gelcoat and then use a barrier paint or primer first? Or if I sand the blue with 80 grit will that be enough prep that I could apply antifouling bottom paint? It's very unlikely this boat will ever see salt water if that matters.
The day after coming out of the lake:
And then after power washing:
