4 stroke Engine oil
Posted: Mon Mar 13, 2017 6:09 pm
Changing the oil in my 60 HP 4 stroke Mercury. What do you use?
Discussions relating to the MacGregor line of trailerable sailboats
https://www.macgregorsailors.com/forum/
https://www.macgregorsailors.com/forum/viewtopic.php?t=26021
I am a big fan of synthetic lubricants (wink-wink), and nothing but AMSOIL goes into my Amphicar if I can help it, in particular their water-resistant grease, which has kept my amphibian clown car's wheel bearings, suspension bits and other water-dunked mechanisms quite happy indeed for over two decades. In fact, in a kind of reverse Hair Care Club for Men move, back in the day I even became an AMSOIL dealer, and the small referral proceeds earned thereby from me and other Amphicar-owning folks using my AMSOIL Dealer Number 508472 when purchasing their slippery goodies (which didn't cost a nickel more to do), helped pay the server rental for the website Amphicar.net. Pretty much mothballed now on the free-hosting service 000webhost.com, the site's still out there as a relic from the dawn of the World Wide Web, still partyin' like it's 1999--though it's nevertheless still pretty damned useful for owners as a repository for lots of technical stuff we "web-toed motorists" need. It was basically intended as the International Amphicar Owners Club's "Slutty Sister Site", where basically any owner with a keyboard and screechy modem could have their way with her, bang together a nice little website, have an @amphicar.net email account, host their images...That sort of thing. Its old AMSOIL for Amphicars catalog page is still there (and may be worth visiting, if only to gaze upon the utterly bodacious "Miss Luberack" of the Eisenhower Era in all her glory surrounded by glassy-eyed slick-haired grease monkey admirers), and while some of the AMSOIL products described in it have long been updated or superceded by newer products, I believe their water resistant grease is still just as it always was: perfect. Based on my long and happy experience with it, I will also put nothing else into my two boat trailers' bearings. If you want to try that grease, I believe you can still use that Dealer Number 508472 when ordering.mallardjusted wrote:I have a 70 Yamaha and a 9.9 Merc on my Mac. I have a 50 Yamaha and 6 Tohatsu on my duckboat. All are 4-strokes. I use synthetic (MobileOne) 10-30W. Meets or exceeds all manufacter's specs.
Those bottom seals, behind the prop, are not for the faint of heart. And in the Honda at least, that bearing housing is probably not coming out without a fight (and something breaking) if it's old like mine.Bilgemaster wrote:The main thing is to change it frequently--like at least once a season, which is super-easy to do, and to make sure what comes out is not "milky" and/or "frothy" like a milkshake from water ingress mixing with the oil. If it is (and thankfully mine was not), then you would do well to replace some seals and whatnot in there that are letting that water seep in. If you're a true novice mechanically speaking, then you might want to just let a professional marine mechanic handle that for you.
You can always do what I did, being only a "semi-novice" engine mechanic. Remove the Lower Unit. Remove the prop. Deliver the LU to a Honda dealer and let a mechanic with the tools and the knowledge do the hard part and replace the seals. I think I only paid $175 or so in labor. You can opt to have them replace the impeller while the LU of off, or replace the impeller yourself when you get the LU back. Be sure to change the O-ring under the Impeller housing too. Even after a new seal replacement I still found some water seepage (but much less than before the new seals) and traced it to that O-ring. After replacing the O-ring it stopped completely.Tomfoolery wrote:Those bottom seals, behind the prop, are not for the faint of heart. And in the Honda at least, that bearing housing is probably not coming out without a fight (and something breaking) if it's old like mine.Bilgemaster wrote:The main thing is to change it frequently--like at least once a season, which is super-easy to do, and to make sure what comes out is not "milky" and/or "frothy" like a milkshake from water ingress mixing with the oil. If it is (and thankfully mine was not), then you would do well to replace some seals and whatnot in there that are letting that water seep in. If you're a true novice mechanically speaking, then you might want to just let a professional marine mechanic handle that for you.
When I was researching water ingress into the LU, there were a lot of stories about folks breaking something trying to get the bearing carrier out. That big aluminium nut doesn't want to come off. Some folks have even broken the LU housing. But I believe it is possible to get the seals out without taking that carrier out of the LU housing by driving in a screw and then yanking it out. Twice, as there's two in there, one facing each way.paul I wrote:You can always do what I did, being only a "semi-novice" engine mechanic. Remove the Lower Unit. Remove the prop. Deliver the LU to a Honda dealer and let a mechanic with the tools and the knowledge do the hard part and replace the seals. I think I only paid $175 or so in labor. You can opt to have them replace the impeller while the LU of off, or replace the impeller yourself when you get the LU back. Be sure to change the O-ring under the Impeller housing too. Even after a new seal replacement I still found some water seepage (but much less than before the new seals) and traced it to that O-ring. After replacing the O-ring it stopped completely.Tomfoolery wrote:Those bottom seals, behind the prop, are not for the faint of heart. And in the Honda at least, that bearing housing is probably not coming out without a fight (and something breaking) if it's old like mine.Bilgemaster wrote:The main thing is to change it frequently--like at least once a season, which is super-easy to do, and to make sure what comes out is not "milky" and/or "frothy" like a milkshake from water ingress mixing with the oil. If it is (and thankfully mine was not), then you would do well to replace some seals and whatnot in there that are letting that water seep in. If you're a true novice mechanically speaking, then you might want to just let a professional marine mechanic handle that for you.
