Mast cap, anchor light, and Windex
Posted: Tue May 02, 2017 7:47 am
Here's an almost-completed new bit of improvement that some others may find useful.
My mast had an aluminium 'mast cap' as it were, welded to the top of the mast, with broken welds, and really serving no purpose. It was drilled and there were a few tapped holes also, so I'm guessing there were things bolted to it at one point. I wanted a real anchor light, and the method I used to mount the Windex was pretty bad (long screws through the backstay chicken head with giant washers), and I needed something useful to do over the winter, so I made a better (IMO) mast cap.
I had some scrap 1/2" Starboard (sheet HDPE) left over from my engine control project, so I traced the outline of the mast, added an extension over part of the chicken head, and cut a cap from the Starboard. I also made a slug for the inside of the mast, which took a number of trips to the disc sander to fine tune to fit, as I wasn't going to pull back the tarp in the winter, at the off-site storage location, just for that. Lastly, I turned a donut to lock the tube to the cap, with a cross pin in a notch to lock it both vertically and against rotation, and screwed the whole mess together with SS screws from my collection.
The light is one of those Perko plug-in pole style 2-mile all-round white lights, which is what my flag staff is (previous owner). I didn't need the light on the top of it, at least not the one that's not higher than the bimini (I have a longer one that gets over top, for when it's in trawler mode with no mast), so I stole that light, and put it on top of a short piece of tube that used to be a kinked spreader. Nothing like retasking scrap, I say.
The longer pole light came with a second lens that's clear on the bottom, which I specifically wanted so that it's visible even close up. The 2-mile rating is maintained, and anyone some distance away sees the side, but approaching an anchorage they'd be looking up somewhat, and many all-round white lights have a narrow vertical azimuth. So this otherwise unused lens was just what I wanted. The socket also has a 5 degree tilt built into it, so I oriented it to counter the 4 degree tilt of the mast. I don't think anyone will notice the 1 degree error, though it's probably more since I don't rake the mast quite that far back.
I changed the bulb out for a Doctor LED replacment (supposedly USCG or Perko approved replacment for the OEM incandescent bulb), to keep battery draw as low as possible.
continued . . .
continued . . .
