Battery up-grade
Posted: Mon May 22, 2017 12:24 am
by Highlander
Well my 12volt house & start batteries gave up the ghost after 8yrs
so exchanged my 12vlt house batt to 2 x 6vlt golf batts
so now the two golf cart batts fit into the same spot the 2 old batts were
had too cut away bottom lip of battery box lid opening to allow for the taller golf cart batts
http://i844.photobucket.com/albums/ab1/ ... ni9zxv.jpg
http://i844.photobucket.com/albums/ab1/ ... am0jcy.jpg
cut off top 1/3rd off new battery boxes to get rid of the battery box handles " not required " needed the space to fit these were the only battery boxes I could find that were the perfect fit from "Walmart" go figure !
http://i844.photobucket.com/albums/ab1/ ... njmkn1.jpg
now need to raise the height of the battery box
http://i844.photobucket.com/albums/ab1/ ... bsm4ji.jpg
so made a cedar frame from 1 1/2" X 1 1/2"
http://i844.photobucket.com/albums/ab1/ ... 6jwqeh.jpg
Installed rivit nuts
http://i844.photobucket.com/albums/ab1/ ... k5rs5l.jpg
http://i844.photobucket.com/albums/ab1/ ... umyjjj.jpg
make new battery box lid
http://i844.photobucket.com/albums/ab1/ ... rg9l4d.jpg
http://i844.photobucket.com/albums/ab1/ ... x6ow0b.jpg
paint edge trim black for 3 - D effect
http://i844.photobucket.com/albums/ab1/ ... lmacne.jpg
Painted cedar frame & while the paints drying changed this fuse panel box
http://i844.photobucket.com/albums/ab1/ ... caezew.jpg
to this one I made with a swing opening door as to a screw on one
http://i844.photobucket.com/albums/ab1/ ... izdci2.jpg
http://i844.photobucket.com/albums/ab1/ ... e6iedg.jpg
http://i844.photobucket.com/albums/ab1/ ... 078vwt.jpg
new battery switch also
will post pic,s of final install, in the mean time I,m making a new battery box mod to relocate the new starting batt under the aft Port side seat & of course this all requires re-routing a lot of wiring & battery cables :x but luckily when I install wiring I always leave an extra 2ft of wire or so , except for the battery cable,s for the start Batt ! . So that will have to b resolved once the start batt is installed :)
Re: Battery up-grade
Posted: Mon May 22, 2017 2:33 am
by kadet
Nice mod but I have never liked wet cells in a tippy boat, too much sulfuric acid to leak out, especially with all your head sails :P
Give me some nice big AGMs 8)
Posted: Mon May 22, 2017 7:35 am
by BOAT
PLEASE CLEAN UP AFTER USING SHOP! RETURN TOOLS!!
You left a big mess to clean up.
Posted: Mon May 22, 2017 8:35 am
by Tomfoolery
Which makes me wonder, what are you using for work space these days, John, now that you live in a group home, er, condo?
Posted: Mon May 22, 2017 8:53 am
by BOAT
Or maybe John gave privileges to some of his neighbors to that big huge garage he has on the back of his property?
( :cry: he did not give ME any privileges, I guess I don't count :cry: )
Posted: Mon May 22, 2017 9:47 am
by Tomfoolery
BOAT wrote:Or maybe John gave privileges to some of his neighbors to that big huge garage he has on the back of his property?
That big huge garage was before he moved to your coast. I didn't think he had one now. But I could be wrong.
What say you there, fuzzy britches? Feel like talkin'? :wink:
Posted: Mon May 22, 2017 9:51 am
by BOAT
People on the west coast don't get out of bed very early - maybe he is still sleeping.
by LoHo
It's a conspiracy, that's what this is...
Posted: Mon May 22, 2017 9:55 am
by BOAT
You don't think they finally caught up to him do you? Geeze, I hope he did not get popped for all those sailboat secrets he sent to Julian Assange - (I hear he and John are best buds).
I think it IS a conspiracy!
Posted: Mon May 22, 2017 11:17 am
by Tomfoolery
LoHo wrote:It's a conspiracy, that's what this is...
:wink:
Posted: Mon May 22, 2017 11:27 am
by Highlander
All is not lost the condo building has a tool/work shop down stairs in the underground parking lot besides the bicycle/kayak storage room :P
well I,m off back down there now to finish off my start batt box brkt,s & then off to the boat to install more pic,s to come later
J :wink:
Posted: Sun Jun 11, 2017 10:13 am
by Highlander
Posted: Sun Jun 11, 2017 10:35 am
by Highlander
Posted: Tue Jun 13, 2017 12:22 pm
by kevinnem
2 questions about the battery isolators ( I think I saw one in the photos).
What happens if you battery on each side are mis- balanced, IE one is at 90% and the other is at 40%? Does most of the charge go in to the lowest one? Or is it split 50/50 even though one battery can't accept it? or is the whole system drops down the the "limiting factor" of the slowest charging( ie fullest) battery?
Also, I read that a isolator can have a .6volt drop from one side to the other. Are you able to measure this or are you otherwise concerned about it?
I am temped to have 2 separate systems 1 for starting and 1 for house load. And a pair of jumper cables should I ever need to connect them.
Posted: Tue Jun 13, 2017 2:41 pm
by sailboatmike
You need one of those fancy intelligent isolation switches that charges the start battery first and then switches over to the secondary battery, was looking at one myself just the other day but seriously doubt I will get that mod done in the short term, many other pressing things need to be done to get the boat better to sail before I worry about that stuff.
