Genoa cover necessary for trailering?
Posted: Mon May 29, 2017 8:32 pm
by bellevuesailor
Hi, I recently purchased a 26M and plan on trailering the boat quite often. My genoa already has UV covers. To protect them during trailering, should I get a genoa cover?
Re: Genoa cover necessary for trailering?
Posted: Mon May 29, 2017 10:00 pm
by Chinook
I would strongly recommend using a sock style sail cover for your furled genoa, when trailering. The force of the wind on that sail, when going down the highway is significant, and can easily cause damage to an unprotected sail. Just consider driving at 60 miles per hour, into a 15 or 20 mph wind. You're quickly dealing with hurricane force wind speeds that can work to lift the edge of your sail. It wouldn't take much luffing to shred a sail.
Posted: Mon May 29, 2017 10:47 pm
by kurz
yes your are right. But the Genoa is closed...
I trailered 1000 of miles, never had a genoa sock. No problems so far.
Just secured with some lines to the mast.
Posted: Tue May 30, 2017 12:11 am
by sailboatmike
Sock is good and cheap to make if you can sew a bit, not even that expensive if you cant sew
Posted: Tue May 30, 2017 12:35 am
by Baha
I would also recommend using a cover. It is very cheap insurance and, if your genoa was to unfurl, you probably would not see it until it was way too late...
Posted: Tue May 30, 2017 7:07 am
by Estate Sail
I cover mine when trailering and when the mast is down. Blue Water Yachts sell a very nice cover.
Posted: Tue May 30, 2017 7:19 am
I just roll mine up on the furler as usual, with several extra turns of the sheets, also as usual, and strap it to the mast with a jillion of those little red ball-end bungies from Walmart. Strapped tight to the mast, it's not going anywhere.
Posted: Wed May 31, 2017 6:59 pm
by bellevuesailor
Thanks everyone. Considering the cost of the sail and the cover, I decided to be on the safe side and get the cover.
