What is the material that covers the bunks?
Posted: Tue Oct 03, 2017 8:12 am
by dlandersson
Ok, I need to recover/renew the material that covers the bunks (wood) that my X rests on on the trailer.
What is the term/terms for it and where can I get it?
Re: What is the material that covers the bunks?
Posted: Tue Oct 03, 2017 8:23 am
by npsrangerchuck
Posted: Tue Oct 03, 2017 9:40 am
by dlandersson
Thanks.
Anyone have any opinions on the best way to fasten the bunk covering to the bunk?
Posted: Tue Oct 03, 2017 9:45 am
I just used cheap indoor/outdoor carpet from Lowes.
Attached with SS staples being careful none faced the hull where it could scratch.
Posted: Tue Oct 03, 2017 10:06 am
by dlandersson
What size staples? I'm thinking monel rust-proof.
RussMT wrote:I just used cheap indoor/outdoor carpet from Lowes.
Posted: Tue Oct 03, 2017 10:32 am
by Tomfoolery
dlandersson wrote:What size staples? I'm thinking monel rust-proof.
I used monel, mostly because that's all that was on the shelf at the time. They're Stanley T-50 narrow crown, 1/2" long (deep) staples.
If I had it to do again, and I will sooner or later, I think I'd buy a cheap Harbor Freight pneumatic stapler. But that's a tool rather than material issue.
Posted: Tue Oct 03, 2017 11:05 am
by dlandersson
Thx - love this site.
Tomfoolery wrote:dlandersson wrote:What size staples? I'm thinking monel rust-proof.
Posted: Tue Oct 03, 2017 1:02 pm
by Wind Chime
I refurbished our 2000 factory trailer a few years ago and replaced our entire bunks with;
- pressure treated 2x4's
- galvanized nuts, bolts, and washers (had to cut the rusted old ones off with sawsall)
- black outdoor carpet
- stainless staples (T-5O)
all off the rack in one buy form Home Depot.
3 years and counting no problems.
If replacing the wood as well - do yourself a favor and label the old ones before taking them off, replacing the new ones is much easier using the old bolt holes for proper positioning
Posted: Tue Oct 03, 2017 1:05 pm
by dlandersson
I'm not sure I understand. Could you come over and show me how you did it?
Wind Chime wrote:I refurbished our 2000 factory trailer a few years ago and replaced our entire bunks with;
Posted: Tue Oct 03, 2017 2:30 pm
by Wind Chime
LOL ... ok, I'll set sail this weekend - should be there by spring
Posted: Wed Oct 04, 2017 5:59 pm
by Chinook
When I replaced my trailer bunks I used plastic material that patio decks are made of, so it wouldn't rot in the future. Easy to cut with a table saw and drill into, and it holds staples for the new carpet pieces just fine. Instead of standard bolts I got some of those nuts which have spikes on them (can't recall what they're called). I drilled counter sink holes for them, and then tapped them into place. They are available in stainless. After stapling new carpet covers into place (used the old carpet for patterns) I was able to bolt them into place with stainless bolts from the underside of the trailer. This makes it easy to unbolt them in order to repaint the trailer.
