Page 1 of 3
26M sink faucet
Posted: Mon Nov 06, 2017 11:15 am
by Obelix
I need to replace my faucet in my 2008 26M
Has anybody any positive or negative experience (i.e. leaking or not holding prime) with the replacement sold by BWY?
Thank you for your opinions
Obelix
Re: 26M sink faucet
Posted: Mon Nov 06, 2017 1:43 pm
by NiceAft
Do you have any other choices?
I’m not trying to be a smart aleck, but if there are no other choices, what choice do you have. If there are other choices, what are they?
The item shown looks to function just like original factory equipment. A simple hand pump.
BWY has a reputation of being pretty reliable with what they sell. Not perfect, but P.D.G. :D
P.S. Here are two that West Marine sells. They are not cheap. :o
https://www.westmarine.com/buy/fynspray ... P000178360?
https://www.westmarine.com/buy/whale-pu ... cordNum=13
Re: 26M sink faucet
Posted: Mon Nov 06, 2017 2:20 pm
by Y.B.Normal
This is basicly an RV sink pump; check your local RV parts outlet.
Re: 26M sink faucet
Posted: Mon Nov 06, 2017 2:23 pm
by NiceAft
Y.B.Normal wrote:This is basicly an RV sink pump; check your local RV parts outlet.
Great idea.
Re: 26M sink faucet
Posted: Mon Nov 06, 2017 2:45 pm
by yukonbob
RV replacement pump aprox $40 cnd or Whale gusher pump $100. Whale is nicer with more flow, smoother etc but it’s up to you as to whether it’s worth twice the price
Re: 26M sink faucet
Posted: Mon Nov 06, 2017 9:02 pm
by Highlander
Gezz Guy,s
I can,t remember when I used mine last I usually just have a 2 gal jug of water on the counter ! :P
Re: 26M sink faucet
Posted: Tue Nov 07, 2017 4:09 am
by NiceAft
Highlander wrote:Gezz Guy,s
Some of us have converted our counter tops. I can still use the cutting board as a counter, but would prefer not placing a 16.6lb (7.5Kg) weight on it. Under the sink is a fine location for the 5 gallon container. In these photos I have not yet hooked up the OEM hand pump faucet.
Re: 26M sink faucet
Posted: Tue Nov 07, 2017 4:19 am
by eodjedi
I use the Jabsco faucet. I bought an ATV Sprayer for about $50. Came with a pump, then I bought the faucet separately from ebay for about $30.00. Normally the faucet comes with a pump which bumps the price up to $130.00 but you can find the faucet separately for much less. Here are some links.
https://www.amazon.com/Ironton-ATV-Spot ... on+sprayer
https://www.ebay.com/itm/Jabsco-Par-Gal ... JP&vxp=mtr
I installed the tank in the bow after I pulled out some floatation foam. Not too worried about losing flotation as the tank is sealed and provides a separate amount of floatation. (empty of course). The Jabsco faucet turns the pump on and off. If you were to use a regular faucet, once the Ironton pump is pressurized, it shuts off automatically. So it gives you two different options for how you want to do your plumbing, a pressured system or on/off pumping.
Re: 26M sink faucet
Posted: Tue Nov 07, 2017 10:51 am
by Highlander
Ray Quote
5 gallons R U Bathing in ur sink ! is that why u had to get a bigger one ? :D :D :D :D
J :P
PS nice work when r u coming over to do mine Eh! :)
Re: 26M sink faucet
Posted: Tue Nov 07, 2017 12:24 pm
by March
Shurflow electric faucet--but you need to get a pump, too. I believe it's worth it
Re: 26M sink faucet
Posted: Tue Nov 07, 2017 2:19 pm
by NiceAft
Highlander wrote:Ray Quote
J :P
It’s actually a smaller sink. It’s a bar sink. I bet that gets your attention John :D
I got the idea (and some detailed info.) from fellow board member, RIS.
Re: 26M sink faucet
Posted: Tue Nov 07, 2017 4:18 pm
by BOAT
I really like the Whales Pumps Flipper faucet - that one looks cool:
Re: 26M sink faucet
Posted: Tue Nov 07, 2017 4:23 pm
I have trouble pumping and washing my hands at the same time. The OEM faucet never primed properly.
I put in a pressure pump and cheap bar sink/faucet. I know, you waste more water, but not if you turn it down to a slow flow.
Re: 26M sink faucet
Posted: Tue Nov 07, 2017 4:31 pm
by BOAT
RussMT wrote:I have trouble pumping and washing my hands at the same time. The OEM faucet never primed properly.
Would it help to put a foot switch on the electric pump? Or something that would turn the water on and off with your elbow or knee or something? :?
I think I could rig up something like that if you think it would help. ?
Re: 26M sink faucet
Posted: Wed Nov 08, 2017 1:51 am
by kurz
I installed an electric pump that stops when the pressure rises.
And a faucet that switches off the pump when turned off.
Yes you use mor water. I allready bought a switch to turn on with the knee but didnt installed yet. Too lazy.
If water consumption is a problem evetually I would put 1 liter in a botle an then rins my hands...
