Galley Mod 26X
Posted: Fri Apr 17, 2020 4:11 am
by Hooky
Re: Galley Mod 26X
Posted: Fri Apr 17, 2020 4:45 am
That is beautiful work.
What is the heat source for the stove, gas or alcohol?
Re: Galley Mod 26X
Posted: Fri Apr 17, 2020 6:05 am
Wow, that is beautiful work.
I'm curious where does that drain hose go to? A thru hull?
Re: Galley Mod 26X
Posted: Fri Apr 17, 2020 6:30 am
by Jimmyt
Very nice! A lot of useful storage created with that. That will make the galley area so much nicer to use!
Re: Galley Mod 26X
Posted: Fri Apr 17, 2020 8:56 am
by adudinsk
Nice Work!
Re: Galley Mod 26X
Posted: Fri Apr 17, 2020 5:01 pm
by Hooky
NiceAft wrote: βFri Apr 17, 2020 4:45 am
Alcohol stove
Re: Galley Mod 26X
Posted: Fri Apr 17, 2020 5:03 pm
by Hooky
Russ wrote: βFri Apr 17, 2020 6:05 am
Hi Russ, itβs a thru hull, I extended the cupboard floors a sides and glassed them direct to the hull
Re: Galley Mod 26X
Posted: Fri Jan 08, 2021 7:18 am
by Greek_sails
This is very nicely done, did you add it on the original galley? I purchased one recently and it just has plastic drawers so I am thinking of doing something similar to what you did(if it is on the original), but due to the lockdown I cannot go to the boat do you happen to have the measurements of the inside?
Re: Galley Mod 26X
Posted: Fri Jan 08, 2021 7:31 am
by Inquisitor
I've never been inside an X. Is that mods to the original galley or a completely new one. Either way, it looks so much nicer than the stock M galley.
I gather the X doesn't slide???
Re: Galley Mod 26X
Posted: Fri Jan 08, 2021 7:08 pm
by ris
The X galley is fixed in place.
Richard
Re: Galley Mod 26X
Posted: Sat Jan 09, 2021 3:41 am
by kurz
Cool. I like the white color!
Re: Galley Mod 26X
Posted: Sat Jan 23, 2021 11:36 pm
by OverEasy
Wow! Nice work! Simple ,clean, even elegant!
Re: Galley Mod 26X
Posted: Mon Jan 25, 2021 11:15 am
by Democritus
Beautiful! So much more usable space!
What are the grates under the table for?
Re: Galley Mod 26X
Posted: Mon Jan 25, 2021 1:02 pm
by C Buchs
To open your drawers, I see you have a latch that you reach through the hole to operate. Can you post more information about what latch you used?
Jeff
Re: Galley Mod 26X
Posted: Mon Feb 22, 2021 10:52 pm
by OverEasy
Hi!
Beautiful galley mod! Nice job!
Now how do I keep this hidden from my wife ........
Opps, too late!
Guess my dual battery/wiring upgrade/new chart plotter/triple bilge pump install project just got a galley upgrade feature.
Fun times full speed ahead........
