Microwave Oven
Posted: Sat Jan 09, 2021 12:19 pm
by Inquisitor
In a similar vane to my Refrigerator thread viewtopic.php?f=8&t=28046 I want to go over a review of a Microwave oven. I'm not trying to convince anyone to change, just to give information so others can make their own "informed" decisions... or at least to kick-start their research. I've gathered much of this from other "off-grid" forums.
Basis
As part of my general upgrading of the M to gain some luxuries, I'm doing a serious upgrade of electrical capacity. viewtopic.php?f=8&t=28020 In it I started out just looking for 100 Ah of capacity, but quickly found the cost of the next "tier" up of 270-280 Ah was not that much more expensive. Also note: because of the robust nature of Lithium chemistry batteries, this is the equivalent to 450 Ah of any lead-acid based chemistry and still have approximately 3000-4000 cycles that lead-acid will never meet.
With this much power, refrigeration, marine electronics, lighting is almost a trickle of usage. It got me thinking about my cooking needs. I was torn about a stove top. The alcohol burners sounded like the safe way to go, but at $350 for a used Origo really hurt my sensibilities... especially since I've made several of the tin-can alcohol burners for backpacking that worked wonders for the price of a couple of empty beer cans. Turning to propane, I have a camp oven I have for car camping that I was considering.
All the extra hardware to do a "reasonably" safe installation (remote tank, remote solenoid valve, ABYC level of installation, propane sniffer) was troubling me on the complexity and safety.
How much would I use the stove tops? How often would I bake a loaf of bread, pizza? Probably not that often in the summer south. We both like to cook elaborate meals at home, but really... we've never go that ambitious on the boat. Anything that ambitious would likely involve a grill on the back of the boat anyway. In this case, a microwave makes a lot of sense. I can boil water for French-press coffee, heat up a bowl of soup, chowder, cook a frozen dinner, popcorn, re-heat leftovers, casseroles far easier and with a whole lot less mess and heat in the cabin.
Research
If you are ever interested in using a microwave off-grid, you must only look at "Inverter" microwaves. If you take nothing else from this thread, this is the most important! I'm no expert... I just learned this on other forums. There are two broad types... Regular and Inverter. Both microwave types have an advertised power and a power usage value. They are not 100% efficient. The advertised wattage is the "cooking" watts of the magnetron. The usage value is how many watts it draws out of your house without tripping the circuit breaker. Typically this is 150% to 200% of the cooking wattage.
Regular Microwave
Regular microwaves use a large transformer that has a huge startup spike to "fill" that transformer before it passes any really high voltage to the magnetron. I've read estimates of 4 to 5 times the rated power. These use pulsing to heat anything below 100% power. For instance, if you've ever defrosted with your home microwave, you'll hear it run a little, go relatively quiet for a little then run hard again. Each time it kicks on, it gets that huge surge of power. So even the cheap $50, 700W Walmart specials, will typically surge to 3500 watts and surely trip your power Inverters.
Inverter Microwave
Inverter microwaves (not to be confused with your power Inverter) doesn't use this large transformer and doesn't pulse. If you set a 50% power setting, it uses 50% of the power, but does it continuously. It uses electronics similar to your power inverter to transform the 120 VAC to the thousands of volts needed by the magnetron. It also does it with a whole lot less "surge". According to a couple of off-grid people in vans, they have successfully run a 1200 watt Inverter Microwave off a 1000 watt power Inverter simply by using a lower power setting on the microwave.
Review
Once I found that I need this "Inverter" microwave, I started looking for specific models. They are rare and thus more expensive. Still concerned about the maximum wattage my chosen Inverter could handle, I started looking for the lowest wattage ones with good reviews. I finally settled on a 950 watt Panasonic https://www.amazon.com/Panasonic-Microw ... B00785MVRA
Purely by happenstance, I discovered my Father has one of these for me to test. :) 8)
Testing
Unfortunately, I do not own an oscilloscope so I am unable to measure the start-up current. I will only be able to see if my chosen inverter can handle it after I finish the Inqism-03 project. I was also hoping I could validate the use statement above about running on a smaller rated power Inverter. Unfortunately, the Inverter I have viewtopic.php?f=8&t=28020&p=347109&hili ... er#p347109 only supplies up to 300 watts and the microwave used right at 300 watts on the lowest setting. I am using a Wemo Insight smart plug that can measure wattage and also measure watt-hours for a test run. Obviously, this is the AC wattage used. The numbers reported below include the AC wattage from the Wemo and projected amps used from the battery assuming a 90% efficiency rating on the power Inverter.
As a real-world gauge, I heated up a frozen dinner. The box's instructions said on high for 6 minutes 30 seconds.
This required 140 AC watt-hours and 13 amp-hours from the battery (calculated).
Although a lot of energy, multiple hits of this usage is well within the capacity of a 270 Ah battery... as long as there is some way to replenish it, if on a long trip.
Re: Microwave Oven
Posted: Mon Jan 11, 2021 5:45 am
by Jimmyt
Very interesting. I see a lot of the big yachts going to all electric cooking. Never thought about it for a trailer boat. Makes pretty good sense when you have the batteries that will support it.
Re: Microwave Oven
Posted: Mon Jan 11, 2021 7:03 am
Jimmyt wrote: Mon Jan 11, 2021 5:45 am Very interesting. I see a lot of the big yachts going to all electric cooking. Never thought about it for a trailer boat. Makes pretty good sense when you have the batteries that will support it.
There's also a significant percentage of RV's going that way, especially large Class A's (buses), and small Class B's (vans). I haven't seen any Class C's (cab-chassis) that are all-electric yet, but they may be out there.
My Class B van is all-electric, but with a 9.6 gallon useable [41 lb] propane tank for heat when there is no AC power available. Or it's too cold for 1800W of electric heat alone. I do have 600Ah of LiFePO4 battery (one giant single unit) and a 150A charger, plus a 280A second alternator on the engine that only serves the house battery, plus 300W of roof solar (big whoop). No generator, and I didn't, and still don't, want one.
I have a 2-burner induction cooktop, with 1800W maximum between the two burners, so if more than one is used at a time, the max heat from either will be limited in order to keep that total at or below 1800W. And a microwave oven (old-style). And a 12VDC/120VAC compressor fridge.
I only use propane for extra heat, or when no AC power is available. And, of course, for my Little Red Campfire unit, with a long hose from the van's propane tank. :wink:
The problem with small boats is how to recharge the batteries, of course. Outboards don't output much to the batteries. Solar is great, as far as it goes, and my 300W of solar (never seen more than 225W actual up here in summer) is enough to keep the battery up when running the fridge/freezer around the clock, though with such a big battery, I could run it for a week or more on just battery power. Cooking takes a lot of energy (anything that makes heat as the primary function does), both induction cooktop and microwave (~150A to the inverter on high). So for extended periods without shore power, charging may be a real problem without a separate generator, in which case you need to burn fuel.
We don't really 'camp' in the van - we use it for travel over long distances, so even without shore power overnight, the diesel (Mercedes Sprinter) with its second alternator takes care of it in short order while driving. But without that capability, we'd have to rely on a generator, which would be the most likely case in a small boat, too.
It's hard to replace the high energy density of liquid fuel.
Sorry for the long post - too much coffee coupled with too much work avoidance. :wink:
Re: Microwave Oven
Posted: Mon Jan 11, 2021 7:22 am
by Inquisitor
Tomfoolery wrote: Mon Jan 11, 2021 7:03 am ...
:D
Thank you... lot's of good information to help fill in my gaps. I hope to sail in the artic North (Maine) and wonder how much can be counted upon in summer.
From what I understand, you can't "just" run the boat motor's alternator to a Lithium chemistry battery like you can to a lead-acid. It'll gluttonously swallow every amp and burn out an alternator... even worse when it's finally full, the BMS will suddenly switch off input and the open line will over-voltage spike the alternator. Your alternator must have the special "stuff" to allow it to charge LiFePO4.
Would you happen to know your fridge specs... size, average 12 VDC usage, etc?
Re: Microwave Oven
Posted: Mon Jan 11, 2021 8:29 am
Inquisitor wrote: Mon Jan 11, 2021 7:22 amWould you happen to know your fridge specs... size, average 12 VDC usage, etc?
It draws about 5.5A at 12VDC. I don't remember if the 0.4A at 120V is accurate. The numbers on their marketing page are incorrect; they seem to be at 24VDC. Others with the same unit report similar numbers as mine.
It runs about 40% of the time in moderate weather. That works out to a little over 50Ah per day, running round the clock on battery power.
There are other brands that claim to be more efficient, some approaching half the current (but don't know about duty cycle), so don't take my numbers as the only ones to use. Many folks here have compressor refrigerators that are portable, which is better suited to small boats. Typically around 50W when running, and you can keep heat leakage into it (and therefore reduce run time) by keeping it in the shade, and putting an insulated blanket over it. Just don't block the air in/out grills.
Re: Microwave Oven
Posted: Mon Jan 11, 2021 6:57 pm
by Brian
You have certainly done your due diligence researching microwave ovens, and refrigerators, but what I am not seeing in either of your threads is where in the cabin you intend to install these appliances? That is of equal importance since there is limited space available, and you want them to be usable without getting in the way.
I installed a Microwave oven back in 2009 which has come in very handy.
https://macgregorsailors.com/mods/index ... em&id=1165
It would be nice to have a refrigerator, but I don't know where I would put it.
Re: Microwave Oven
Posted: Tue Jan 12, 2021 4:59 am
by Inquisitor
Brian wrote: Mon Jan 11, 2021 6:57 pm You have certainly done your due diligence researching microwave ovens, and refrigerators, but what I am not seeing in either of your threads is where in the cabin you intend to install these appliances? That is of equal importance since there is limited space available, and you want them to be usable without getting in the way.
Your Microwave
I have to say, that is a perfect Mod! It's so unobtrusive as to be not even noticed. I tried looking up details of your Origo Microwave. Since it's no longer in production, I couldn't find anything. My security software rejected any site that had old manuals. Would you mind sharing. All my due diligence is purely reading and hearsay of other forums. I haven't ever done what you have successfully completed and lived with.
  • If it's an inverter type
  • What it's labeled wattage
  • What kind of power system you have. I see in 2009 you intended to eventually get an inverter, et al.
  • Since it's a 2009 project, you must have good, solid impressions of its value, problems (or not)
Where to put it
That's a loaded question. For most people, what you have is perfect. Most people want to go sailing (master of the obvious :o ). Carpentry work is just not something they really can or want to do. A smaller subset of the forum are quite happy doing a project. You are obviously one. Then there is a Fringe subset (we ain't quite right 8)). We're willing to actually tear apart things that might devalue the boat. I've written mine off... to never be sold. I am trying to figure a way to cut it in half and make it into a 32 footer. ( :D Joke). That's just crazy talk.
I'd say if you are closer to the former, you might put a chest fridge in the standard, aft-berth :macm: location. According to most of my reading, if it stays sealed, you can turn off its power over night so you don't have it running next to you in the aft berth. One step further, you could make a nice wood cabinet for sound deadening and/or added insulation. The major problems with this solution are how much of the berth it uses and how inconvenient it is to access. I'm afraid I don't have a middle ground suggestion.
Fringe
I like designing and building every bit as much as sailing. Being land-locked, its a good thing. I have a series of Mods that are prefixed with Inqism. This Inverter and the Fridge threads are spin-offs of Inqism-03 Electrifying as they may be useful to others in their own right. Currently, I have 15 Inqism projects in various stages of brainstorming, designing, and building. The number and order are routinely changed as I learn new things or add fluff-projects like Inqism-02. I've only published 5 so far. Currently, my Fridge and Microwave will be installed as part of Inqism-08. If you're really willing to join the Fringe, you can see where I'm going with two posts I made starting here: viewtopic.php?f=9&t=27492&hilit=storage ... 15#p346678
Re: Microwave Oven
Posted: Thu Dec 16, 2021 12:28 am
by OverEasy
Hi All
This thread has a great start but we’re wondering if there has been any further progress?
Best Regards
Over Easy
Re: Microwave Oven
Posted: Thu Dec 16, 2021 4:13 am
by Starscream
OverEasy wrote: Thu Dec 16, 2021 12:28 am Hi All
Best Regards
Over Easy
We haven't heard from Inquisitor in months, it seems. I hope he's still OK and still Mac-ing.
Re: Microwave Oven
Posted: Thu Dec 16, 2021 8:40 am
by OverEasy
Thanks for the note back StarScream
Yes, we hope all is OK with Inquisitor too!
Hoping he is just too busy finishing up his mods to post them before winter settles in.
(But who doesn’t enjoy working on one’s boat with single digit temps and snow covering everything? …… That’s why we’re done in SC where we can nostalgically remember the fun of working through New England winters :D :D 🥶🥶)
Maybe we should send up a flare?🤔
Best Regards
Over Easy
Re: Microwave Oven
Posted: Thu Dec 16, 2021 9:12 am
Inquisitor is still with us. His was last active on December 16, 2021 :o That's today 8)
Re: Microwave Oven
Posted: Thu Dec 16, 2021 10:39 am
by kmclemore
NiceAft wrote: Thu Dec 16, 2021 9:12 am Inquisitor is still with us. His was last active on December 16, 2021 :o That's today 8)
My guess is he popped in when he got an email alert that his thread had been responded to.
Re: Microwave Oven
Posted: Thu Dec 16, 2021 2:02 pm
Maybe he will pop in again with all of this traffic?
