Page 1 of 3
Mac26X Cabin Stair Mod
Posted: Wed Apr 21, 2021 2:04 pm
by OverEasy
Re: Mac26X Cabin Stair Mod
Posted: Wed Apr 21, 2021 4:15 pm
by pitchpolehobie
Maybe the greatest mod of all time.
Posted: Thu Apr 22, 2021 8:19 am
by rsvpasap
This is an excellent modification. I totally removed the steps on my 2002 26X many years ago and you've inspired me to consider reinstalling.
Posted: Thu Apr 22, 2021 10:50 am
by Sheppie62
I want to know how to install a ladder instead of my stoop (98’s don’t have a ladder). Stoop is alway in the way, wish bottom part was gone as well.
Posted: Thu Apr 22, 2021 11:41 am
by OverEasy
Hi Sheppie62
Not sure exactly what a ‘98 looks like....
Maybe we can get a couple perspective/dimensional views (front-to-rear, side, top-down, diagonals) for those of us not familiar with that layout?
Posted: Thu Apr 22, 2021 12:12 pm
by C Buchs
I bet you could adapt the late model ladder, but I don't know that for sure. I checked to see of BWY sell a replacement ladder and they don't. Sometimes their descriptions say something like "this is a nice upgrade for earlier models". They do have the brackets
http://shop.bwyachts.com/product-p/6404-1x3.htm.
Where are you located? Maybe somebody lives near you and you could see it first hand.
Jeff
Posted: Thu Apr 22, 2021 1:15 pm
by Sheppie62
Southern California, I’m thinking a marine salvage yard would be good place to start. Or weld it myself, I’ve been thinking of trying to learn to weld stainless steel.
Posted: Thu Apr 22, 2021 1:40 pm
by Sheppie62
What is in the bottom stoop? Anybody know if it can be removed?
Posted: Thu Apr 22, 2021 5:00 pm
by K9Kampers
Sheppie62 wrote: ↑Thu Apr 22, 2021 1:40 pm
That "bottom stoop", or step, is removable. It covers the ballast fill valve and vent plug. There is a page on that, with pictures, in the owner's manual. If you don't have the owner's manual, it can be downloaded from the RESOURCES page on the Main Site.
Posted: Thu Apr 22, 2021 5:23 pm
by C Buchs
K9Kampers wrote: ↑Thu Apr 22, 2021 5:00 pm
The original
had the ballast vent under that step. It was then moved to under the v-birth. The transition boats still had the step, but no vent under it. I'm not sure of the dates of the transition.
Jeff
Posted: Thu Apr 22, 2021 6:57 pm
by svscott
OverEasy wrote: ↑Thu Apr 22, 2021 11:41 am
Hi Sheppie62
I just looked through a bunch of my photos and ended up needing to take a screenshot from a video to get this view of the aft berth and companionway step on my 1998 X. Sadly, I don't have pics with side view, top-down, or diagonals... maybe if you tilt your head when looking at this one.
Posted: Fri Apr 23, 2021 4:53 am
That's what my '99 looks like. Mine doesn't have the vent under the step. There's nothing under the step. MacGregor just hadn't gotten to using the new mold without the bump-out and raised area where that box step connects.
It's not worth the trouble for me, as I don't use the space under the helm for anything but a little storage, but that raised bump could be cut off and capped with a nice bit of teak. With a new fold-up ladder, of course.
Posted: Fri Apr 23, 2021 9:08 am
by Sheppie62
For the fiberglass experts here, how hard would it be to eliminate then entire step and make it look like it was never there? I’m not a fiberglass guy. I have seen miracles done with fiberglass so I know it can be done. I suppose I could just cut it down flat and put something on top of it (teak?)
Posted: Fri Apr 23, 2021 10:06 am
by OverEasy
Hi!
If we look at the screen from the sides we can see the profile very nicely. Same when looking down from the top.....
So it looks to be a 2-piece sort of thingy .... removable piece and a molded in piece that sorta bumps out into the walk area?
If yours doesn’t have the ballast vent in there then there shouldn’t be an issue with removing them.
If you want to do a fiberglassover it could be a good starter project.
Some good resources start with a YouTube site called “BoatWorksToday” I believe. Nice knowledgeable guy whose business is boat fiberglass work.
Fiberglassing can be a rewarding process to get back to a surface that looks like it was original or better. But it does take time and work to achieve.....
Posted: Fri Apr 23, 2021 12:35 pm
by Be Free
I always assumed that this was a factory setup on my 2001
This is the hinge that allows the ladder to be raised up in front of the companionway. It does not interfere with any of the seats.
The ladder is held up by a strap with a snap on the bottom of the top step. The other half of the snap is on the batten board (washboard). I also have a short length of rope tied to the bottom of the ladder (port side) that I can loop around the port winch if I want to keep the ladder up while the companionway is open.
