Lights and fans
dpknopf29
Sailboat: MacGregor 26D
Lights and fans
Post by dpknopf29 »
I need to purchase cabin lights and fans. Any recommended brands or types?
pitchpolehobie
Re: Lights and fans
Post by pitchpolehobie »
I can't imagine I paid 40$ for it but got this last year. Charges via micro USB and usb-c the clamp is really strong as well. Pretty happy with it.
https://www.amazon.com/OPOLAR-10000m ... XVJDYM
2002 MacGregor 26X: Remedium
Tohatsu 25HP
Re: Lights and fans
Many years ago I did a lot of research on fans and their wattage draw. The lowest draw fan I could find were the Hella Marine fans (available in white and black). They're not cheap, but they barely sip the power. Here's the kind I bought:
https://www.hodgesmarine.com/hel0033610 ... black.html
Here are some other relevant discussions on the subject (try the 'search' function on the upper right of this page):
viewtopic.php?f=8&t=24780
viewtopic.php?f=9&t=19779
viewtopic.php?f=8&t=13726
March
Re: Lights and fans
Post by March »
Looks like a 24 V fan. I also have a rechargeable USB fan (can't remember the type, but it was around 20 bucks) The plug broke, couldn't find a replacement, and haven't used it since. I wouldn't mind wiring it permanently to 12 V, if that type is available, and if it only sips--under the cockpit, for the V-Birth is right under the hatch and that's good enough
One of the earliest "unhappy mods" I did was to mount a solar vent right at the end of the port bench, in the cockpit. I thought the cockpit cushion may be folded so the battery will recharge and blow some air right underneath where I sleep. Didn't work as planned. Could barely feel the airflow, I always stumbled when I wanted to go topside to the mast... so I promptly plugged up the hole and left it at that. Now the hole is leaking under rain and I will have to remove it and silicone it properly once again
C Buchs
Re: Lights and fans
Post by C Buchs »
Regarding lights:
This is a good thread: viewtopic.php?f=8&t=26638&start=15
I put these in the cabin: single https://www.amazon.com/gp/product/B00CZ ... UTF8&psc=1 and double https://www.amazon.com/gp/product/B00CZ ... UTF8&psc=1
I added this https://www.amazon.com/gp/product/B00K2 ... UTF8&psc=1 red tail light lens repair tape to the inside of one of the double light's lenses. Now I have a red light in the cabin that I can turn on to preserve night vision and a white one when we're settled in somewhere.
Jeff
pitchpolehobie
Re: Lights and fans
I have been looking for a suitable cabin LED for night time. I ended up finding these but also like Jeff's lens tape idea.
https://www.ebay.com/itm/252621757392
Tohatsu 25HP
C Buchs
Re: Lights and fans
Post by C Buchs »
Full disclosure, the red lens tape was an idea I got from a discussion on this site. I think it was Tom's idea, but I can't remember. I just implemented it.
I couldn't find a picture with the red light on, but here's my light mounted with the white light on.
Jeff
Re: Lights and fans
I have one of the pricey Caframo fans, with the timer and three speeds. Very energy efficient. But it costs.
There's a discussion right now on an RV forum I frequent about the Fantastic Vent 12" box fan that runs on 12VDC. It looks like it uses the same multi-wing blade as the powered roof vent in my van. It's also pricey, but given its size, should move more air overall, and is probably more efficient due to being larger diameter, assuming the same air flow as a smaller one. Which is not necessarily a safe assumption, but that's how fans work. :|
https://www.endlessbreeze.com/
Some folks use battery box fans from O2Cool with good results. Long, skinny blades for efficiency. The AC adapter is (supposedly) rated 0.5A at 12VDC, so less than 6W for the fan on high speed. If it is indeed a 12VDC motor, then you should be able to connect to the boat's system, though I don't know what will happen when the OB or external boat battery charger jacks that up to 13.5V or higher; probably nothing, but I don't know that for fact. In the Q&A section, someone says they're running it off a 12V deep-cycle system, so I guess it works fine.
Hmmmm . . . Amazon link doesn't work. But easily searched out.
Tom
Be seeing you . . .
dpknopf29
Re: Lights and fans
Post by dpknopf29 »
Thanks for the many ideas!
Re: Lights and fans
We have something like this. Runs on its own power or 12v
https://www.amazon.com/O2COOL-10-Inch-P ... 014CLAL8S/
[Posted link fixed. -kmclemore]
