26X shroud and backstay tension
Posted: Sat Jun 26, 2021 5:54 pm
by pitchpolehobie
I measured my uppers and they were both 33.
My lowers were 8 and tightened to 14.
My backstay was less than zero and tightening with my weight of 170lbs brought it to 0
https://www.marinechandlery.com/media/c ... auge_1.jpg
That's the gauge I used
We used this guage and my shrouds are 1/8 so the above measurements would correlate to
Uppers ~33= 320lbs
Lowers~14=120lbs ish
Backstay ~0=0ish lbs I suppose when at the dock? Diff when downwind?
Reviewed this: http://www.bwyachts.com/rig_tuning_tips.htm
Am I in the right neighborhood?
Re: 26X shroud and backstay tension
Posted: Sun Jun 27, 2021 3:44 am
by dlandersson
Ok, my backstay is generally pretty slack? :|
pitchpolehobie wrote: Sat Jun 26, 2021 5:54 pm 26X shroud and backstay tension
33= 320lbs
14=120lbs ish
0=0ish I suppose when at the dock.
Posted: Sun Jun 27, 2021 8:42 am
by Be Free
The backstay does not do anything unless you are running (wind behind you). It is not unusual for it to be slack at other times.
Posted: Sun Jun 27, 2021 6:21 pm
by wakataka
Sounds like you could still tighten it up a bit. Here's a good thread on rigging
http://www.macgregorsailors.com/forum/v ... 26&start=0
Posted: Sun Jun 27, 2021 6:51 pm
by pitchpolehobie
wakataka wrote: Sun Jun 27, 2021 6:21 pm Sounds like you could still tighten it up a bit. Here's a good thread on rigging
seems to be a pretty useful thread. thanks! im gonna keep working on it and post updates. Ill say with my above numbers the boat felt a little "smoother" going on tacks in 20mph wind today. Seems my inner shrouds could still be tightened up a touch. :macx:
Posted: Mon Jun 28, 2021 8:25 am
by Be Free
Sounds like you are starting to get the tension dialed-in for your boat. At 20mph I've found that the :macx: is happier with at least a single reef. I go faster and things stop falling off other things. :)
