After many years of using my
Especially in small ports in italien lakes in front of all caffes we missed the comfort.
So I went for the following:
I installed the porta potti 335. The reasen was that it is to the smallest one because in the
You also can se the shower curtain I installed all around. The idea of showering is that you sit on the closed portapotty. You can close with the shower curtain 360 degree.
That the water cannot enter in the cabin I siliconed a grey board in (see next pic).
In the next photo you can see the water drain hole.
Unfortunately the normal shower sump pump was to big to store. I mounted it but in 99% id did not work. So the next step was to install a normal self-priming pump to pump out all the shower water directly out of the boat.
In the next pic you can see the channel I constructed from a cable channel. With sillicon I glued in a hose that then brings the water from the shower to the pump.
This channel with hose I finally squeezed under the hole from the shower, and again fixed and sealed it with silicone.
That was quite tinkering. But finally I can say that it works and I bring the shower water out easily.
As you can see: This is no shower room with golden faucets an fancy tiles. But it gives in a small boat a possibility for showering in privacy.
