Replacing Rudder Gudgeon 26X 1999
Posted: Tue Jan 11, 2022 1:02 am
by keithl
The rudder gudgeon (bracket) on the starboard side is aluminium while the port side is stainless. The previous owner bent and tore the aluminium bracket. I have purchased a stainless steel bracket.
THE QUESTION :
Do the securing bolts go through the transom i.e. bolt + washer + locknut .
Re: Replacing Rudder Gudgeon 26X 1999
Posted: Tue Jan 11, 2022 9:39 am
by chipveres
By actual measurement, the transom on my Mac 22 is 1/4 inch thick. If your 26 is similar, through-bolting is the only way to go.
Chip V.
Posted: Thu Jan 13, 2022 6:11 pm
by keithl
Thankyou Chipveres.
Posted: Fri Jan 14, 2022 5:20 am
by Jimmyt
keithl wrote: ↑Tue Jan 11, 2022 1:02 am
THE QUESTION :
I am hoping an X owner will answer you, but I'll give you a power sailer response, anyway.
The transom on the M is pretty thick, due to carrying a big outboard for planing use. I would expect the X to be similar. All of mt rudder bracketry is through-bolted and bedded in 4200 (I hope it's not 5200).
Lower rudder brackets at bottom of pic. As Chip says above, yours are likely to be through-bolted.
Transom thickness at my bilge pump discharge ( midway up transom) is about 7/16".
Maybe one of the X Owners can give you the real story.
Posted: Fri Jan 14, 2022 5:02 pm
by Be Free
I'll climb into the back of mine tomorrow and see if I can give you an answer.
Posted: Sat Jan 15, 2022 12:15 pm
by Be Free
I did not find any signs of bolts, nuts, or washers in the area behind my gudgeons. From the outside they appear to be held in with large lag bolts. I did find some very sharp fiberglass shards though.
