Putting a Portable Generator on a Mac?
Posted: Tue Jan 10, 2023 1:44 pm
Hi All!
With Winter settling in, cockpit temperatures plummeting into negative numbers, as the bow struggles to point into bitter winds
howling through ice encased rigging, snow
accumulating in mast high drifts on the foredeck, and daylight
only a weak glimmer on the southern horizon it’s time to pause for a moment while hauling
firewood back on a toboggan
to the log
cabin and grab hold of the distance hope of a future season of warmth 🏝 , sunshine
and water
in liquid form (if such a thing actually still exists)…..to contemplate what Mac Mods one would like to have accomplished should that distant vision of Summer become a reality.
One of the mods we are attempting is the addition of an AC shore power connection and shipboard AC Electrical Interface & Control Panel.
In working through the needs for a separate AC box, circuit breakers, galvanic isolators, hull mounted shore power connectors and possibly new cables one aspect still in need of research is that of a portable onboard AC generator and where to put it?
While this is a new to me item I figure that it isn’t the first time someone has done this.
Never one to turn down the experiences of others, good ideas, considerations or good advice of others (before attempting to reinvent a wheel 🛞 that already exists
) I’d like to take the opportunity to solicit the members of our forum who may have already done this, or are also contemplating this, Mod for their opinions, advice, suggestions, cautions and experiences.
A) What portable generator did you/would you select?
B) How did/would you interface to it electrically?
C) Where/How did/would you mount it?
D) What did you like/dislike about using your generator operationally?
E) Can you share any photos or diagrams of what you did or plan to do?
—-> Note: Pictures of good and bad examples you may have come across would also be appreciated!
Best Regards
Over Easy
Best Regards
Over Easy
