Reattaching mast step. Where to seal?
Chumpy36
Post by Chumpy36 »
I have completed a deck repair and it’s time to reattach the step. Where should I put butyl tape to seal? My thought is around each hole on the deck (see pic) and around each bolt under the cap on the topside (see pic).
Am I on the right track? Btw, I did drill the holes oversize, epoxied then drilled correct size for the bolts. Seems good
topcat0399
Sailboat: Venture 2-24
Re: Reattaching mast step. Where to seal?
Post by topcat0399 »
I think you are on the right track but;
I just don't think you are going to get a good long lasting reliable seal if
you leave that deck as it is and slap that step plate on there.
Those ragged edges of gel coat, gel coat cracks, and not having a countersink
is not going to do your butyl tape any favors.
What I would do; grind off all of the gel coat to the shape of the foot print of the mast step.
I would then mix up some splooge (thickened epoxy or poly resin), lay proud in the foot print,
put the bolts in your mast step, and slap that mast step down into the splooge
(wax the bottom of the mast step - or a stretched plastic bag works- and bolts to keep from sticking to the splooge)
Put a brick on it until it sets up (or put the nuts/washers on).
Now the deck and the mast step will be in perfect harmony.
Redrill your holes from below, use a counter sink on the top of the holes.
Use this method:
https://marinehowto.com/bed-it-tape/
To apply your butyl tape
Seems like a lot I know but if this spot has any chance at all of leaking - it will leak.
There is significant downward pressure on that step when the rig is up.
I think the majority of damage and seal breaking occurs when the mast step is torqued around
by the mast during raising/lowering, especially if anything goes awry during those operations.
It don't take much with that long long mast as a lever...
Some of us go as far a putting a backing plate inside under the deck just because.
I used a 1/8" alum plate. Plywood will work, or very stiff plastic sheeting, whatever floats your boat.
Its just there to spread the load of the bolts and help keep the step from torquing around.
At a minimum you should clean up that ragged gel coat around the holes and try to countersink somehow
so that your butyl tape has a place to live around the bolts.
Just my take - been there more than once and learned the hard way.....
-Lake Petenwell, WI
-1973 Macgregor Venture V224 (iron keel - Yea!)
-1978 Evinrude 15 Long Shaft Electric Start
Chumpy36
Post by Chumpy36 »
Thanks for the reply...
So there's a synthetic wood block UNDER the mast step plate (hard to see in the pic). Do I need to worry about a seal between it and the wood block?
I can countersink the deck holes no problem. I'm not quite sure I understand the epoxy bit. Are we trying to make sure that any gaps between the wood block and the deck are taken up? If so, I get that. Not quite sure how I keep it from sticking. Won't a plastic bag still bond to the thickened epoxy? You're saying put the bag over the bottom of the block and then poke the bolts through?
Thanks for the help!
Wyb2
Sailboat: MacGregor 25
Post by Wyb2 »
You just don’t want water hiding anywhere. Lay a layer of butyl on the full area between the deck the spacer block, and between the spacer block and the step. When you tighten the hardware 90% of it will squeeze out, that’s fine, butyl is cheap and you can even reuse the squeeze-out.
You definitely need to clean the deck a bit. I usually alternate a manual wire brush with acetone wipes. Sandpaper if it’s giving me a hard time. Also, the gel coat around your holes is pretty badly cracked, you should at least countersink a little, but maybe just sand it back a little. You just don’t want any loose chips breaking off near the hole.
