Replacing companionway & hatch slides
macowneril2015
- Location: Downtown Chicago, 2001 26X, 2001 50 Hp Nissan (NS50D2)
I recently began attempting to replace my slides/ rails on the sliding hatch and companionway. I have ran into an issue primarily on the starboard slide on my 2000
. The issue is the bathroom bulkhead insert blocks access to to the plugs and bolts to remove them, I tried drilling a hole to get access to one but it is not feasible on the others. I know I will need to drill into liner for one of the sliding hatch ones and I have replacement plugs but any help or advice is appreciated.
- WinSome
Re: Replacing companionway & hatch slides
What is the issue you are trying to resolve? Our hatch slide was grinding and being difficult. We used one side of self/sticking industrial grade Velcro inserted under the hatch slide. Had great results. Found such info in the mods section!
macowneril2015
Please see the attached images the first one is of the inside of the bathroom where the liner is blocking access to the nuts for the bolts. I tried to drill one out but the other is not as useful (red mark shows approximate location of inaccessible nut access point). I bought replacement rails from BWY but they did not have any suggestions on replacing them. The second picture shows the condition of the rail and access point issues.
- Dougiestyle
Here is a link to how i did mine.
Dougiestyle
C Buchs
Here are a couple more pictures of how I did mine. I used butyl to seal everything back up. I found that putting a little ball in my socket was a good way to hold the nut in place while I wedged my socket into some spots.
After removing the top bolts that hold the head wall in place I wedged a piece of wood into the gap to open it up enough to get to the bolts.
I couldn't get a socket with the nut into that hole, so I screwed this locking nut onto this longer screw backward so that I could get it in there and started.
Good luck...Jeff
Good luck...Jeff
macowneril2015
I wish I had posted and seen this before I drilled an access hole for the metal screw but this was very helpful I appreciate the detail of this video.
macowneril2015
Jeff,C Buchs wrote: ↑Tue Sep 12, 2023 8:07 am Here are a couple more pictures of how I did mine. I used butyl to seal everything back up. I found that putting a little ball in my socket was a good way to hold the nut in place while I wedged my socket into some spots.
Good luck...Jeff
You saved me trying to remove the insert, I was nervous to force it but these photos saved me. This forum has been an absolute lifesaver
