Garage
Posted: Tue Feb 13, 2024 4:33 am
by chadwiseman
I’m building a new garage in my property and would love to use one bay to store my boat in the winter. I’m thinking an 9 ft wide garage door by 8 ft high should be fine. With a garage dept of 32 ft.
Re: Garage
Posted: Tue Feb 13, 2024 5:49 am
by pitchpolehobie
With mast and stanchions on a 26x? I think you need 10ft
Somebody posted a pic of measurements once. I think i settled on 10ft high door and 32ft length w motor in raised position.
Re: Garage
Posted: Tue Feb 13, 2024 6:09 am
This thread might help.
viewtopic.php?t=19142
My BWY manual for the 26M states.
I'm not sure if the 26X can store the mast on the deck
Re: Garage
Posted: Tue Feb 13, 2024 8:04 am
by Be Free
I'm putting up a garage for my "X" as well. When I started planning I measured 10' from the tip of the mast to the ground so I'm putting up a 12' garage. You need to check the actual measurement on
your boat though. Your garage won't care how tall my boat is when it breaks your mast.
Re: Garage
Posted: Tue Feb 13, 2024 7:16 pm
by Jimmyt
That’s how close the fit is with a 10 ft door.
And the tongue jack has to be extended pretty far to make the clearance at the end of the mast.
Re: Garage
Posted: Wed Feb 14, 2024 5:01 am
by Be Free
Now you have me wondering about my own measurement. I don't remember if the jack was all the way in or all the way out when I took that measurement. Good thing I have not committed to a garage height yet.
I'm heading out to go see Willie Nelson in St. Augustine tonight. It's going to have to wait until I get back.
Re: Garage
Posted: Wed Feb 14, 2024 8:06 am
by Jimmyt
Sounds like you’ve got your priorities dialed-in!
I brought mine into the opening slowly until the mast got too close to the top of the opening. Then, I raised the jack until I got the clearance I needed. Then, I painted a white stripe on the jack so I can always raise it to the right spot. If I don’t see the white, I know it ain’t right…
Of course, I have to remember to look for the stripe.
Re: Garage
Posted: Thu Feb 15, 2024 6:32 am
by dlandersson
Yeah, I'd go with 12' too
Be Free wrote: ↑Tue Feb 13, 2024 8:04 am
Re: Garage
Posted: Fri Feb 16, 2024 3:19 pm
by 45Plus+
Maybe its just me, but I'd go as high as I could afford. Nothing worse than a lack of headspace when you need to mess around in the cockpit once the boat is in the garage. I'd also be thinking about resell value - i.e.; for the next people who might want to buy your house and would be helped along in their decision if they knew their RV fit in the garage.
Re: Garage
Posted: Fri Feb 16, 2024 3:57 pm
45Plus+ wrote: ↑Fri Feb 16, 2024 3:19 pm
You initially missed out on a 2005. Not trying to take this thread on a tangent, but 45plus+, what year
did you get? If you have posted it, I don’t remember seeing it.
Re: Garage
Posted: Sat Feb 17, 2024 3:38 am
by dlandersson
Nice point
NiceAft wrote: ↑Fri Feb 16, 2024 3:57 pm
Re: Garage
Posted: Sat Feb 17, 2024 4:08 am
dlandersson wrote: ↑Sat Feb 17, 2024 3:38 am
Nice point
Thanks D.L., but it wasn’t me. It was 45Plus+.
Re: Garage
Posted: Sat Feb 17, 2024 7:53 am
by Be Free
Where I live I have to deal with high winds fairly often and higher walls mean higher wind loads. During the last hurricane that hit here I clocked 130mph sustained winds just a few feet from where the boat will be.
Re: Garage
Posted: Sat Feb 17, 2024 9:23 am
When I saw that chadwiseman lives in St. John’s, I had a similar thought; only not just for wind, but snow too. Since chadwiseman only says he live in St. John’s, it could be Antigua, they also get hurricanes.
Re: Garage
Posted: Sun Feb 18, 2024 5:08 pm
by chadwiseman
Yeah we get lots of wind here in St. John’s, NL, canada… im probably going with 9ft doors and just remove the mast before i park it. It will only be moved in for winter storage and removed for the other 6 months a year.
