Upper shroud and forestay attachment
Posted: Thu Apr 04, 2024 7:43 am
by Prospect
My boat doesn't have the tabs connected to the upper shrouds. It just didn't come with them. Is this normal? My upper shrouds fit directly into the pin shackle.
Re: Upper shroud and forestay attachment
Posted: Fri Apr 05, 2024 6:05 am
What is "normal" is what is pictured in the photo you attached. At least that's what I have.
I don't know how to remove those "tabs" without re-swagging the fittings.
Without them, the shrouds would be too short. Therefore yours might have been made custom or before Roger added the "tabs".
Posted: Tue Apr 09, 2024 5:52 am
by THE CUSCUS
That is totally wrong setup. The uppers need to be on the back side of the mast (swept back spreaders right??) Those tabs are held on by the bolt going through the mast and angle to the rear of mast. The forestay attaches to the mast hound facing forwards. Having some kind of swivel joint is a good idea too.
Posted: Tue Apr 09, 2024 6:42 am
by NiceAft
THE CUSCUS wrote: Tue Apr 09, 2024 5:52 am That is totally wrong setup. The uppers need to be on the back side of the mast (swept back spreaders right??) Those tabs are held on by the bolt going through the mast and angle to the rear of mast. The forestay attaches to the mast hound facing forwards. Having some kind of swivel joint is a good idea too.
For a Venture 25, the setup is different.
For an :macm: , the photo is correct.
Posted: Tue Apr 09, 2024 9:18 am
by THE CUSCUS
My bad for not seeing the OP had an :macm: I figured the rigs on all the Macs were more similar. That set-up would make Rube Goldberg jealous.
Posted: Tue Apr 09, 2024 1:58 pm
by NiceAft
:D Thanks.
That’s what we have to deal with.
Now, on a tangent; I see where you you are, or at least where the boat is. We will be taking a cruise out of Haver de Grace this June. Is there a chance to meet for dinner? We try to meet members of this site when we travel.
Posted: Wed Apr 10, 2024 10:03 am
by THE CUSCUS
Ray, yes I live a short boat ride (or a longer car ride in miles) from HDG. My wife and I frequently go there for dinner. Let me know when you are there and we can see if we can get together. Always good to meet fellow Mac owners.
