Getting a new rub rail... what else?
Chumpy36
Post by Chumpy36 »
Should the seams be sealed under the rub rail? Anything else I should be doing when I'm in there? I'm hoping to avoid leaks.
26S by the way...
Thanks!
Re: Getting a new rub rail... what else?
Installing new rub rail :)
Chumpy36 wrote: Thu Jun 13, 2024 7:03 pm Should the seams be sealed under the rub rail? Anything else I should be doing when I'm in there? I'm hoping to avoid leaks.
26S by the way...
Thanks!
Starscream
Post by Starscream »
26S by the way...
Thanks!
I sealed the top of the rubrail with black Mono Ultra Exterior more than 5 years , and its held up perfectly. Zero detachment, but a bit of color fade. I wasn't worried about the underside, but I may go back and do that to try to combat the spiders.
