Auxiliary outboard for 26M
Posted: Sun Mar 30, 2025 11:37 am
by Shane anthony
Was thinking something like this might be an answer to auxiliary power if the main would go down. The smaller tube shape of the shaft might fit between the main and rudder without interfering with movement. I haven’t measured anything but was thinking mounting it would be simple compared to a traditional outboard. Not saying this would be a totally ideal way to go but for me I’m on Commencement Bay, and would only need to get back to the marina that’s very close by. I’m still new to boating (first year) and learning about everything, have taken a 3day course that covers the very basics. And will be taking a more advanced course covering anchor, and docking. I’ve been out at least 20 times and am learning but always have the fear of the main going out and not having a backup. I’d rather have a second engine and have a plan C to deploy an anchor and call the nearby boat towing service. I have the number and talked to the owner @ BoatUS Tacoma so I know how things work. Anyhow just wondering if anyone tried this or maybe it’s just something that won’t work due to hp or other reasons. Your thoughts would be appreciated thanks.
Re: Auxiliary outboard for 26M
Posted: Sun Mar 30, 2025 1:28 pm
by NiceAft
I believe the most difficult part of mounting an auxiliary outboard on an
is the limited flat surface on the stern, allowing clearance for the rudders.. Highlander made a special mount which curved around the starboard side. I don’t have any photos. Maybe he see’s this post and adds his undeniable mod expertise.
P.S. if I remember from other posts on this topic, 4HP will move an
in calm seas and not against the tide. If I’m wrong, someone with experience (Not Theory) will correct me.
Posted: Sun Mar 30, 2025 4:58 pm
by Shane anthony
NiceAft wrote: ↑Sun Mar 30, 2025 1:28 pm
Thanks for your insight, was trying to lookup Highlanders mod. Still looking he has a lot of posts
Posted: Sun Mar 30, 2025 7:29 pm
by NiceAft
Shane anthony wrote: ↑Sun Mar 30, 2025 4:58 pm
Send John an email. You will find it when you press on
Posted: Mon Mar 31, 2025 12:41 am
by Shane anthony
NiceAft wrote: ↑Sun Mar 30, 2025 7:29 pm
Great Thanks!
Posted: Mon Mar 31, 2025 8:25 am
My 2.5hp on my dinghy pushed my Mac along nicely at around 5mph in normal (calm) seas.
As you mentioned, the trick is mounting the thing. I wish there were an easy location. I've always thought in an emergency I could use my dinghy and motor as a tug alongside of the boat.
Lugging all that extra stuff has lost its luster. My dinghy and motor are in the garage all the time now. I maintain the outboard, clean fuel, good filters and hope it will keep running. ONE time the motor started running poorly at the beginning of the season. Changing the spark plugs fixed it.
At the risk of jinxing myself, my motor has run very well. I always use ethanol free gas and installed a pre-filter water separator. So far so good.
Posted: Mon Mar 31, 2025 6:11 pm
by Shane anthony
Thanks for the info, I think I’m understanding the special mount. One way to do it would basically be to turn a small section of the rounded corner of the boat to a 90° corner with a couple SS steel plates welded at a tapered 90° then bolt one side to the stern and the other to the side. Something I could build out of thin plywood to get all the angles and a good visual, Hopefully it wouldn’t look to ugly.
Posted: Tue Apr 01, 2025 5:24 am
by WinSome
FYI suggestion. Replace the plywood spacers you refer to with $ store cutting boards. It’s inexpensive, and won’t rot, and can be cut, molded and might not even need painting.
Posted: Tue Apr 01, 2025 11:01 am
by Shane anthony
WinSome wrote: ↑Tue Apr 01, 2025 5:24 am
Sorry, I wasn’t very clear about it. I was just going to use the plywood for making a template.
Posted: Tue Apr 01, 2025 11:13 am
by NiceAft
I think Highlander made a mold that fit the curve. Hopefully he see’s this thread and responds.
Posted: Tue Apr 01, 2025 5:25 pm
by Shane anthony
NiceAft wrote: ↑Tue Apr 01, 2025 11:13 am
That would be great!
Posted: Mon Apr 21, 2025 1:48 pm
by Lars H
I was thinking along the same lines but with their electric saltwater model. At about 20lbs I could keep it attached to the rail until needed. Wasn't sure that one would fit on the transom either.
Hate to haul a dinghy.
Larry
Posted: Fri May 16, 2025 2:14 pm
by 45Plus+
Shane
I too, as relatively new to large boat sailing, wondered about aux power options for my M as well. Nothing like having a plan b that would get you back to port - even if slowly. The M doesn't have good aux motor mounting spots like the X so I will follow this chat to see where it goes with respect to mounting options - even if only temporary for emergencies only. That small outboard you found looks like it has the right characteristics - light, and skinny. It would be great if it could fit on the well beside the main engine with or without having to raise the rudders. It will be interesting to see what comes of this discussion. The subject brings to mind those outboards used in SE Asia that essentially look like whipper snippers with a propeller on the end of a very long pole. Checking on Google, it appears converting weed wackers to outboards is a thing:
https://www.pdbmagazine.com/2017/04/pdb ... conversion Now you just need a way to mount one on the rear rail of an M.
Posted: Fri May 16, 2025 3:31 pm
by NiceAft
Posted: Fri May 16, 2025 11:44 pm
by kurz
Why you cannot use long screws to fix the bracket? And control the distance with nuts and washers?
