I'm on the struggle-boat
Chumpy36
Post by Chumpy36 »
trying to figure out what are essential items on the boat. I'm a pack rat and I need help paring down.
right now I keep...
1. Small tool kit
2. drill and bits
3. small vacuum to clean up and associated battery and charger (ryobi)
4. Foodstuffs (freezedried mostly) a jet boil, a pressure cooker (small) and plates and such. A pot or two as well. I have a induction hot plate as well but waffling if this is needed
5. bedding and pillows
6. A couple of chairs that work in the cabin and in the cockpit.
7. cockpit cushions
8. a rubbermaid box of spare hardware and bolts
9. a bin of odds and ends like paper towels, swimming towels and clothes
10 sail bags
11. Gas and oil for outboard
12. fire extinguishers
13. Tarps for boom tent
14. camping chair
15. Extra anchor and rode
I think that's it.
I'm trying to maximize living room as much as possible.
Am I forgetting any essentials or have things I don't need?
Thanks much
Re: I'm on the struggle-boat
Spare fuses in all your amperage values
Some lengths of wire for repairs
Selection of crimp-on electrical connections, including eyes, blade plugs (M&F), and splicing connectors
Heat shrink tubing
Box of waterproof matches
Spare pins for rigging (several sizes)
Length of rope w/ handle for hand-starting the motor
First Aid kit
Air horn (or manual hailing horn)
Small container of lubricating grease (a small Vaseline container is fine)
Selection of zip-ties for quick repairs
Some kind of water pump (req in the US by the Coast Guard)
kmclemore wrote: Mon May 05, 2025 10:37 pm Spare fuses in all your amperage values
Heat shrink tubing
First Aid kit
dustoff
Post by dustoff »
Chumpy,
the list of essentials depends a lot on what your boat use-case and the conditions in which you're going to routinely store and use it.
For example, if you're essentially a day sailor who keeps his boat in a local marina and never goes outside the range of TowBoatUS, you really don't need to keep too much of the tools and spares onboard the boat. Things like spare props and associated tools are just not needed. You're just not likely to do any significant repairs or need substantive supplies on the water in that scenario. In general you'll probably want to minimize stuff on the boat to improve motoring performance too.
Now a completely different scenario would be someone who keeps the boat in the driveway and goes out for multi-day trips in coastal waters 6 or 7 times a season. In that case, you would want to have most of your stuff on the boat with just a few things to load pack at the last minute that are trip-specific. You want to be as self-sufficient as possible given trailer weight, interior space, and boat performance.
so I would devise a packing list specific to your seasonal conditions.
v/r
:macm:
Chumpy36
Post by Chumpy36 »
dlandersson wrote: Tue May 06, 2025 3:20 am Some kind of water pump (req in the US by the Coast Guard)
Heat shrink tubing
First Aid kit
to bail with?
Chumpy36
Post by Chumpy36 »
dustoff wrote: Tue May 06, 2025 7:22 am Chumpy,
v/r
Right now, I'm in a wet slip at Lake Lanier and I do overnights (motoring mostly until I feel more confident singlehanding) but I eventually want to do longer cruises either around Lanier or coastal sailing.
Right now I feel like I'm set up in between those two use cases.
PhysicsTeacher
Location: Abbotsford, BC, Canada 1999 26X, 60 HP Yamaha
Post by PhysicsTeacher »
Although I have a fancy bailing pump on board, I've found that these from the Dollar Store work very well:
https://www.dollartree.com/h2o-blasters ... -in/252267
The pointy end lets me get into corners much better than any standard bailing pump. I keep one on my dinghy and one in my cabin.
And, yes, the bonus is that on a hot day you can squirt people with it . . .
Hi!
I’m with Dustoff on this…
What are you’re doing and who you’re doing it with will determine what you’re gonna need.
Basics start with all the required USCG require nta for a 26 ft vessel. After that are a valid First Aid Kit and the knowledge of how to use it.
Next would be basic emergency water, medications and food stuffs that you don’t need to cook and sufficient bottled water for the number expected to be aboard for a reasonable time frame (which goes back to how you will use your boat) so no one gets dehydrated or blood sugar level issues, especially if anyone has diabetes or is pre-diabetic or heart medications etc…
If on populated waters within cell phone range a TowBoat membership takes care of getting you back to the ramp to haul out and repair at home for anything serious. Minor stuff one of those hand tool kits suffices for tools. A Duct tape or Flex Seal tape roll is not a bad idea. I like to have a tube of stick water epoxy on board but we get a bit farther afield. I like to keep the general boat stuff aboard but I could just as easily leave it home if I needed to save space… I just like/need to putter around when I have idle time.
Comfortable folding cushion seats for the anticipated number of passengers that can still tuck away when not in use is a nice creature comfort but things can be shared to save space.
A Porto-let, flush water filled and spare sanitation tablets. Toilet paper and spare roll, Hand sanitizer and a pack of fresh wipes to freshen up/clean-up.
Extra LED headlamp and two sets of spare batteries.
An appropriate anchor with at least 150 ft of twisted three strand anchor line.
Four boat lines sufficient to adequately tie up and sufficient fenders for both sides.
A spare 50 ft line just in case
A spare blanket in addition to planned sleeping gear.
A plastic “police” or “coach” whistle which is a lot more effective than shouting or fumbling around for an air horn (on my experience). You wear it on a lanyard
A small table top LED lantern is nice (along with two spare sets of batteries)
A can & bottle opener , paper or plastic plates and eating utensils of your choice
I prefer to keep a multi tool &/or a sharp “Swiss Army” type knife on a lanyard handy hanging up in the cabin
A box of tissues and a roll of paper towels
I prefer and have installed 3 electric bilge pumps on circuit breakers. They will work better, faster, more effectively than solely relying upon a manual hand pump plus they will work automatically while freeing up me to deal with the issue(s) that made them come on in the first place. They are a problem mitigation tool to buy time to take appropriate action. They are much more effective than any hand pumping. (Note: The Mac26X has three primary bilge areas… port & starboard outside the ballast transfer tubes and center between the transfer tubes.)
We keep our boat in a seasonal slip and find having a good battery chargers on board helps keep the batteries topped up. We also have a small wet/dry vacuum to clean-up as wet as to suck up any trace water in the bilges the sump pumps don’t get.
We find having a dual switchable battery system is useful and gives some backup capability if used properly.
A cell phone charging outlet and charging adapter and appropriate cable are quite useful.
A secondary fire suppression extinguisher is also beneficial. To be effective any extinguisher must be in sight and readily avialable at all times… when it’s needed there is NO TIME to be fumbling around remembering where it is and digging it out.
We like to carry ginger chews to help prevent/mitigate sea sickness as well as some hard candies to enjoy.
A selection of various size ziplock bags always seem to come in handy. A couple plastic grocery bags as garbage bags help keep things nice and tidy with not much space required. The can be tied shut, stored and are easily carried to where they can be properly disposed of.
We have been using a thermonic cooler for several years that can run on shore power (via an adapter) or on 12 volt power while the engine is running. It holds the cold very well and essential eliminates the need to bring/buy ice cubes for a regular cooler.
We also switched over all our onboard electrical systems to reset-able circuit breakers which eliminates needing any spare fuses and the awkwardness of finding and replacing blown fuses.
Some type of pillows that can be used for support as well as sleeping are handy to have. One per person staying on board is generally sufficient.
A good easily used and read current chart, an appropriate compass are baseline for navigation. A pair of good small binoculars helps too!
If you can afford it a good marine grade GPS with the current chart chip for your area is nice to have… often you can get a combination unit that includes a sonar transponder for depth and bottom information if you like.
A good VHF radio system can be very helpful when needed.
If you keep on top of your space management and organizational skills this isn’t all that hard to accomplish…. Again this all depends upon how you will be actually using your boat.
We use a variety of lock lid clear sided bins set from Huffy or Lowe’s that have a somewhat common format so the various sizes work together. We modified or galley to allow us to use 6 open top bins for the most commonly used items.
Hope this helps….
Best Regards
Over Easy 8) 8)
Post by Ixneigh »
Basic tools, some way to keep them dry.
Oddball electric stuff and a car style circuit tester. Spare rigging stuff. Rings, some shackles. The mid sheet shackle can fall off sometimes. Have an extra of those and superglue the pin into it when you reinstall it.
You’re not going to do much on the engine but I do keep
plugs, filters, prop wrench, spare prop
Some epoxy glue, sealant, double sided tape.
Spare GPS and batteries. Lots of flashlights, phone cables.
Solar anchor light, plus solar strobe light
Bosuns supplies. Dyneema lashing line, dyneema winch line, 3/8 size, various lines of all sizes, including a tow line to tow other boats or get yours towed, extra anchor, extra oar locks
First aid stuff including UV penlight,
For cruising, I add fishing gear two cast nets, dip net, crab trap, extra tackle hooks line, etc. You may want possibly extra sails, additional tools like saw, hammer, chisels, some scrap wood, dust mask, gloves, sandpaper.
Extra solar panel, small gas “bush charger” for those cloudy weeks, extra hanging camping lantern, extra cutlery and galley stuff, extra mask and fins, bathing suit, bottom scrubbers and scrapers, sunscreen, lotion, water filters rain catcher, stove parts, stuff to cook on shore if permitted,
The list is nearly endless.
I can’t stress the cobalt drill bits enough though. If you have to drill anything on a boat, it’s not going to be because you just want something to do. It’s going to be because something is broken and needs repair. Good quality bits can make or break that endeavor.
"Shoal Idea"
2011 M, white
Tohatsu 20
South Fl.
TrailerTrash
Sailboat: MacGregor 26D
Post by TrailerTrash »
I have the opposite problem. I used to backpack frequently, so I've emptied everything I don't need and am looking at ways to reduce weight. I tend to get obsessive, so moderating that desire requires conscious effort.
dustoff
Post by dustoff »
I noticed everyone, me included, neglected to mention much about cookware, cooking appliances, dishware, and eating utensils. This is actually one of the most important lists of things that you will customize and evolve, and will be very required for almost all types of use cases, from day sailor to a Bahamas expedition. Great onboard food and drinks is the recipe to a fantastic experience on your MacGregor with friends and family. I have a full set of cooking utensils in a nice roll-up storage case, a nice durable lightweight (plastic) dining set for 6, a Magma kettle grill that I mount on back rail when cooking and at least two full bottles of propane stored under the stern seats, water boiling pot, skillet, and sauce pans with lids that fit alcohol stove size, a backup butane countertop burner in case I need a second burner for food prep, (think bacon, eggs, potatoes, and Texas toast, and pancakes all ready before anything gets cold), cloth and paper napkins, backup additional plastic/paper flatware, dry condiments and spices. Hmm. this is making me hungry...
:macm:
If you’re looking fo a compact kitchen here’s one that fits the bill “with room to spare” !
posting.php?mode=reply&t=30318
ART005
Post by ART005 »
To the OP. I'm starting 4th season as 3rd owner of Mac26S. The 2nd owner was pretty good. I'm still removing (and adding i guess) stuff. Filling empty home bedroom. Clever plastic storage containers are useful.
