I'm not denying that low current draw is important. If your usage pattern is as you state it and you believe it's justified, or if you just have $$ to burn, go for it.
I've had my X for five years, been on several longer trips, including one away from shore power for ten days. I enjoy sailing much more than powering, and believe I run my motor less than almost any other Mac owner I know.
And I believe I can count the times I've run my motor less than an hour on any given day on a closed fist. Also, given an adequate sized house battery, it's not the usage over a given day that matters, it's the average over the long term, so if there were some days I ran it less, and I've forgotten, I'm quite sure that I made up for it the next day or the day after that by running it two or three or more hours. Heck, when it comes right down to it, if I had no other choice I'd not be averse to running the motor for a half hour or so, while sailing, just to charge the batteries. And mine is a noisy, smelly gas hog two-stroke.
Even if you never run your motor, at 6Ah per day for the anchor light, an 80Ah battery will power it for more than six days without recharging at all and without exceeding Moe's magic 50% discharge level. Heck, if you're only going to do it one or two times a year, it won't instantly kill your house battery to run past the 50% discharge level. It might only last four years instead of five.
I know once you've bought your 100,000 hour LED light you'll (at least theoretically) never have to buy another, but at $40 for an 80Ah marine battery at WalMart, you could do buy a new battery three times in 12 years, and still have some enough left over for battery hold down hardware, compared to the LED light. And BTW, we use thousands of 50,000 hour LEDs per year in the product my company manufactures. That's nearly six years of continuous on time, which I'll wager none of our products actually sees, and yet we regularly replace fried LEDs on products which have been in the field only a fraction of that time.
I know, you've got other stuff that uses power as well, and you can't just run out and buy another house battery each time you put another 6Ah per day power consumer on line, but I still believe on the whole it's pretty hard to justify a $130 anchor light under any criteria.
I also know, $130 isn't a huge amount compared to some of the other stuff we blow money on, but part of my resistance is purely philosphical. Looking at the simple technology, materials, and even throwing in an hefty kicker for engineering, R&D, and reasonable profit, for the life of me I can't see why an LED anchor light ought to cost $130. It looks to me like the only explanation is the common "MMF", or "Marine Multiplication Factor. When the price is reduced to something reasonable and justifiable, I'll probably buy one.
Finally, and just to jerk your chain one more time, my Aqua Signal Series 20 anchor light draws 5W not 10W; so all the above arguments times two (-$21 at West Marine if you don't already have an anchor light).
