Honda BF50 Waterpump
Posted: Sun Apr 04, 2004 7:42 pm
I have a 2001 Honda BF50 on my 26X. As I am getting ready for the sailing season, I am considering replacing the water pump impeller. The motor has only had 3 seasons, the last one in salt water and the pump appears to be working fine (I always rinse after a trip). However, the single most reason for failure is a bad water pump.
I have the Seloc 1978-1999 repair manual (there does not appear one on the market for the 2001 model). The manual tells me that I should drain the gear oil, remove the prop etc.
It seems to me that I should simply unbolt the lower unit, which should then give me access to the waterpump.
I would like to hear from someone who has done this job on the Honda. Could you provide the steps involved? How much time does it take?
Your help is much appreciated.
Regards,
Harry
Regards,
Harry
