Rudder bolts
Posted: Fri Apr 28, 2006 2:53 pm
by fran trapp
Does anyone happen to know the diameter of the bolts holding the rudder on for a 96X. Mine are really rubbing where the steering is attached. I think that i need to get washers to lift the steering arm up. Any other suggestions? :macx:
Posted: Fri Apr 28, 2006 3:52 pm
by LOUIS B HOLUB
My solution for any stainless washers, nuts, or small bolts is Ace Hardware. Im not sure if you have an outlet in your area...but hardware stores are much more reasonable than Marine Outlets...
Posted: Fri Apr 28, 2006 6:33 pm
by Sloop John B
Yeah, heck, just take the old one off and stick it in your pocket and hike on down to True Value, Ace, etc.
If you need a bushing because of wear, measure it with different coins and explain it to these guys and see if they have something you can slide in there.
Posted: Fri Apr 28, 2006 8:19 pm
by craiglaforce
I think I had a similar problem with my 97. The bolt was digging grooves into the gelcoat. I think it was mainly from previous owner stepping on the rudderhead. I put some washers under my bolt and that fixed it. I didn't want to risk bending it back. Nut sure the diameter, probably 3/8 or a tad bigger.
Posted: Fri Apr 28, 2006 10:59 pm
by Don T
Hello:
My 95 has 3/8" bolts. I put nylon bushings between the bracket and the rudder head. I also changed over to stainless carriage bolts (filed the hole square). Nice rounded head doesn't gouge the deck.
Posted: Sat Apr 29, 2006 8:55 am
by fran trapp
Thanks so much. I'm off to get the materials to fix it. I am wondering if liting the motor causes this?
