Motor - Battery Issue, very strange
Posted: Mon Jun 19, 2006 7:35 am
I had a wonderful Fathers Day. We took the Mac to Lakefront Park, Saint Could, FL. I have posted before, this is a very nice marina on a lake that is basically 5 miles in diameter and averages 8 to 10 feet deep.
But there is always something that goes wrong, I have learned this, more detail below and sorry for the long post.
We had a light rain in the morning, but the forecast was supposed to be good after that. We drove there (about 30 min.) and 10 min. out rain stopped and the boat was pretty dry from driving down the freeway.
We rigged the boat with no problems.
I have learned, there is always something perplexing with the boat.
The water was about 2 feet low, had to back the boat past the end of the ramp dock. Have the boat in the water, floating, I jump into the cockpit. I turn on the power (I always put the switch on both unless I know I will be using the power without motor for a very extend period of time.
I lift the motor off the safety block, swing that out of the way and begin to lower the motor and it drops to about the same distance it was lifted and just stops, as though I had no power what so ever. Very strange since it had only been 19 days since I had her out (can the battery be dead in that short period of time)?
I kept hitting the switch, and then I put in the key and turned it, nothing, just as though there was 0 power going to the motor. I grabbed my portable jump battery, went down below and hooked it up to (what I believe is the start batter (have large posts like a car batter, it was the one on the left). What appears to be the house battery is the one on the right, had smaller posts and several thing hooked up to it.
I went up, nothing still, I switch to the other battery, nothing, I played with the switch, nothing. I was in a rush since I was sitting in the ramp (Good thing they have 3 ramps so you dont have cars lining up behind you), but I think I had left the charger on the motor battery?
I turned on the radio to see if there was power and there was (of course I know that could just be the house battery). Since I was in a rush I dont remember if I left the jumper connect to the start battery, but this time I went up and what I did was turn the motor with the wheel, and suddenly it was working. I dont think it was leaned over that much but can that prevent it from tilting up and down? I have a Suzuki 50? Or was the battery dead and after leaving the portable jumper on there for a few min. helped? Just dont know? I would think when you hook them up they would be like a new battery that the motor pulls from? I did have the switch on for jumping and it was fully charged.
Just hoping someone know what this is or has experience this. My concern is since I dont know what the problem was nor the fix, I am concerned about it happening again.
For the good news, had a great sail, overcast, so no sun, and no bimini! Brisk wind around a steady 10 to 12 knots, and we were cruising (with 6 on board) between 5 and 6 MPH (according to the GPS) with just the genoa. I have like sailing with just that and not even having the boom on the boat when we have all 6, I feel we have more room. But we need to get used to have the book there, just lazy on my part, one less thing to hook up.
