Seafoam
Posted: Tue Feb 13, 2007 12:03 pm
by Francis
This is a pretty simple question, but where can I buy some seafoam for my motor? We do not have any really good boat shops here so I have to send out for things. Also I was thinking of disconnecting the fule line that goes into the carb so that I can squirt some in and let it set for a day or two. Will that do the job of cleaning it out?
Thanks
Posted: Tue Feb 13, 2007 1:41 pm
by RobertKing
Im in Florida and I can get it at most auto suply stores, same in Minnesota and Mississippi. You might have to ask them to carry it.
B-12
Posted: Tue Feb 13, 2007 2:27 pm
by Timm Miller
You can aslo use something from Walmart called Berrymans B-12....I used two cans per 12 gal. tanks and it cleared up a clogged carb that I had. Runs about 3.xx per can vs. 5.xx for Seafoam. I like Seafoam for fogging my engine and laying it up for the Winter but the B-12 cleared my dirty carb problem. Run your motor hard for about an hour.
Posted: Tue Feb 13, 2007 3:42 pm
by Larry W
I get Seafoam at the local AutoZone. Use it as a stabilizer more than a cleaner but ever since using it religiously, haven't had a problem with the carbs on any of my motors (boat, lawnmower, generator, etc.). The directions say you can pour it directly into the fuel lines, but I've never tried that.
Posted: Wed Feb 14, 2007 7:49 am
by tangentair
try googling "seafoam fuel additive bobs cycle shop" they have it for less than 7 per can
seafoam
Posted: Thu Feb 15, 2007 6:50 am
by Francis
Thanks everyone for the info.
I will look at these places and try to located it.
Thanks again
