Project M - Five Second Dinette
Currie
Post by Currie »
Hello all,
Not to keep doing this ad-nauseum, but it's fun - plus now I'm 95% sure I'm looking for a 2003/2004 26M. I imagine someone has thought along these lines before, but I wanted to work it out and do some designs.
Since the 03/04 model doesn't have a permanent dinette, I've been struggling to come up with an idea that doesn't mean struggling with a removable table.
This one folds up into the galley around the daggerboard chute. I did some measurements from the factory drawings and it looks like everything works out ok, although the table is shorter than the factory one - only about 30", or slightly less, in length, but that's alright for me and how I would use it.
The only trouble I see is having to either cut a slot thru the galley top (as shown), or make a heavy-duty bracket that wraps around it - to the hinge underneath. The pics explain the rest. It should be quite sturdy, as it is supported at four points (there's a small bracket on the galley that you can't see). The flaps can lift up on either side (with inset hinges), and fold completely over, for walking through to the head, or cooking at the galley. They snap in, with a button-in-socket type deal. Also, the support leg will probably have a pin at the bottom to hold it in place when deployed. I haven't bothered to draw any buckles and clasps to hold everything in place, but they would be there.
I think the table in the first pic is drawn a little long, but it shows the idea.
I enjoy challenging woodworking projects, so I'd be ok with the construction, but without a boat yet :P anyone see any reason this wouldn't work? So far I've only checked the dimensions against the factory drawings. Let me know your thoughts. Thanks!
~ Bob
Wonderful idea, Bob!
The only change I'd make is to not make those little 'ears' at the back end of the table - I'd make it straight across. The ears will make it more difficult to slide around the end of the table on the port side, going forward.
Currie
Post by Currie »
Thanks Kevin,
The little ears may amount to nothing at all, all the way up to a couple of inches. I can't be sure without a real boat. They do block the way completely, however, since they provide a vital bearing point for sturdiness. To walk forward, one would lift the leaf, then walk thru. It's very possible the table would be straight and just the corner would rest on the settee arm-rest/cabinet. It would come down to the final ergonomics :)
Cheers, and thanks again
~ Bob
Currie
Post by Currie »
Hehe,
Ugh...I actually drew the final pic with the wrong design :? :P The second pic shows that the leaves and supports will jam on the leg when you try to drop them. The right way to do it is not that different so I won't bother to post a new one. It's just an extra notch that gets covered up by that "keeper" trim piece.
~ Bob
On Edit: The mistake was driving me nuts :P I fixed it.
Kevin
Location: Roseville, California USA "Toucan" Tanton 43 Cat Ketch
Post by Kevin »
This is a very pretty concept.
JJ
Post by JJ »
Very Nice. Mind if we "borrow" your idea!!
impinnacr
Sailboat: MacGregor 26D
Post by impinnacr »
very nice! I can see that working very well on the 26 classic daggerboard boats.
Chris
Jack Sparrow
Location: Cairns, Australia 2007 M 50 Yamaha Run to Paradise
Post by Jack Sparrow »
Currie
It looks good I wish I was that handy with wood, I have posted some mods we did on the panels above the table the gaps on the electronics panel are for winter instalations sorry I can't link it yet
Currie
Post by Currie »
Thanks guys!
JJ - only requirement is that you post pics when it's done :-)
Jack - great job! I love the flat screen display. I've been wondering where I might put one myself. Thanks for posting the pics.
~ Bob
Richard O'Brien
Post by Richard O'Brien »
Very handsome concept . You really are an excellent illustrator. I applaud what I 've seen. The problem I have had with my '04 M galley isn't removing the dinette table, as much as wanting a smaller "Prep" area? I've been toying with the idea of a fold down smaller cutting board attached to the starboard section above the seat cushions. The cushions might get stained but you'd have a place to stand. The original design doesn't have a support leg, allowing you to slide in and out easily.
Paul S
Post by Paul S »
Here was my (somewhat more basic) solution
http://www.geocities.com/yellow_mgb/mac ... 26M_table/
It is a 2 piece design, and it doubles as a table for the cockpit as well
Paul
Currie
Post by Currie »
Very nice mod Paul - and smart to make it double as a cockpit table. Thanks!
~Bob
