Adding a Little more water capacity
Posted: Fri May 11, 2007 7:27 am
by Divecoz
I am heading up to the boat, and while there will be looking at adding a Little more water capacity. We have the 5 gallon camper bag that came with the boat. I was thinking of adding another bag in parralell. A clear hose from each bag to a Tee and the Tee up to a new 12V. Pump/Faucet.
Any reason why this wouldn't work well? Should I just be looking for a long narrow flexible tank instead? I for now keep the bag in the cubby storage under the sliding galley. If for a longer trip, should I look for a tank that will fit under the rear berth? My concern with a larger tank is,
it will be seldom used and might I need to "bleach it" when not in use ?
Posted: Fri May 11, 2007 7:49 am
by baldbaby2000
I don't see why it wouldn't work. Sounds like I have the same setup as you and I just orient the water bag so that the outlet is off to the side or down a little so the pump can prime easier. Eventually the air gets sucked out and there's not problem. Often I carry 2 of those bags and just switch over when the first is empty but maybe I'll consider your idea.
Water bag
Posted: Fri May 11, 2007 9:01 am
by Terry
Richard:
Don't you have a significant other that insists on presurized water?
The Admiral of my ship had me deep six that goofy camper bag you speak of after couple summers. It was not so bad with just day sailing, but once the extended trips started, she started in about the tap pump and camper bag. As per orders from the top I now have an electric pump and dual electric/pump tap and the smaller 50 liter plastimo water bag. It fits quite nicely under the aft berth just behind the companionway ladder. I find the square 50 liter is just enough, but in hindsight perhaps I should have got the longer rectangular bag (130 liter) and only fill it half. During off season you can put Arm & Hammer Baking Soda in it to keep it fresh. During sailing season you need to make more use of it to keep a fresh supply of water circulating through. It is surprising how much more use it gets when you have electric pressurized water system.
Yet another project to embark on, as if you didn't have enough with all the extra wiring you are going to do, oh well there is wiring with the water too.
Posted: Fri May 11, 2007 10:07 am
by Duane Dunn, Allegro
I went with two hard coleman 5 gallon tanks. We find we get 2 - 3 days from one tank with my family of 5 on board. They fit easily up front in an X, an M might be more of a challenge to find a place. I fitted a dip tube to one of their caps and it is simple to switch tanks. I still like being able to remove the tanks for easy filling and cleaning. Even out at anchor we can dinghy in and fill the water at a park.
The plumbing feeds a 'on demand' pump (I've disconnected my head faucet as we never used that sink). I like these a lot better than the true marine pressure pumps. There is no pressure left in the lines to cause leaks over time. The galley sink faucet has a switch in it so when you turn the water on the pump turns on. Clean simple, leak free, no accumulator tanks. The pump and faucet were around $60 (looks like more now).
http://www.westmarine.com/webapp/wcs/st ... artial/0/0
Posted: Fri May 11, 2007 10:34 am
by Bobby T.-26X #4767
i have two of these in my X (galley and head).
Jabsco Pump & Faucet
i remember paying about $50 on-line for the package (pump & faucet).
i use the OEM flexible Mac tanks that can be purchased at WalMart.
since they're only $5 each, i usually keep a couple of extra on board.
i think that your T concept will work fine.
Bob T.
"DāBob"
Dinghy Motor: '06 2.5-Suzuki
Posted: Fri May 11, 2007 12:42 pm
by Paul S
I just added a 50 gallon flexible tank under the rear berth of our 04M.The bladder fit nice. Takes a while to add 50 gallons of water! But should be good. We have a 12v pressure water..and the 16 gallon seemed to run out too fast
I would suggest losing the 5 gallon and getting a larger one and putting it under the rear berth..as the space is not useful for a lot of stuff
Paul
Bag
Posted: Mon May 14, 2007 2:38 pm
by pokerrick1
Divecoz;
Just for the record, my Wal Mart sells the EXACT same 5 gallon bag that came with my
for $4.99, which I thought was pretty cheap for an extra water supply.
I see no reason why it wouldn't work in parallel - - - and it's a simple, cheap fix. (That's me - - - simple, cheap)
Rick
Re: Bag
Posted: Mon May 14, 2007 5:41 pm
by Divecoz
pokerrick1 wrote:Divecoz;
Rick
Rick I am really leaning towards the twin bags as I can fill-em in the boat or even carry them on-board from a on shore supply.
Heading for Mexico and will be back in about 10 days . What the heck its 80 in Chicago and I am heading to Cozumel????
Re: Bag
Posted: Mon May 14, 2007 5:47 pm
by pokerrick1
Divecoz wrote:What the heck its 80 in Chicago and I am heading to Cozumel????
I'd rather be in Cozumel (or La Paz) than Chicago also
Rick
Re: Bag
Posted: Mon May 14, 2007 7:13 pm
by Divecoz
pokerrick1 wrote:Divecoz wrote:What the heck its 80 in Chicago and I am heading to Cozumel????
Rick
Kind of surprised you don't mention Chicago, as there are some Big Games around here $$$$$
Re: Bag
Posted: Mon May 14, 2007 8:27 pm
by pokerrick1
Divecoz writes: quote]
Kind of surprised you don't mention Chicago, as there are some Big Games around here $$$$$[/quote]
Not bigger than here - - - but I don't need big games anyway - - - when I play I leave my ego home - - -I don't want to play with good players - - - I want to play with complete donkeys with $$$$
Rick
Posted: Mon May 14, 2007 8:43 pm
by Divecoz
OH ! Those North Shore Country Club Bozo's Hahahaha$$$$
Willing to PAY$$ to learn. Or to get even with the wife having a spending spree at Needless Markup and Bend over for the teller.
Ahhh yes my X father in law dropped many a boat buck at the Country Club during a friendly game or 30
Mexico
Posted: Mon May 14, 2007 9:33 pm
by pokerrick1
Posted: Fri Jun 15, 2007 12:17 am
by tico
Are these faucet fits right on?
I am about to change the manual faucet that came with the X 1996 boat.
How is the water pressure, high, or low, or medium? (kit above mentioned)
If they fit right on it, I will get two of those babies.
Tico
Pura Vida
Posted: Fri Jun 15, 2007 7:03 pm
by aya16
The faucet on my M was mounted next to the old hand pump in the sink.
I use the hand pump to pump out of one of those 2.5 gallon square sparkletts bottles, I just cut a hole in the top and run the hose into it.
The pressure water faucet draws from a 13 gallon collapsible tank installed on the other side of the boat. The pressure is low and at first
I didnt think I would like it. But with low pressure it takes a while to drain the 13 gallon tank and gives enough pressure to wash or fill dog water bowl. Things like that. It will fill the sink in about a min or so.
I dont like those camping 5 gallon tanks that came with the boat. ( yes walmart sells them cheap) because the fiberglass in the compartment
where it was stored put a hole in one I used. The 2.5 sparkletts bottle is much tougher plastic.
Other ways to have more water without having to carry a large tank.
the ice from your Ice chest when melted will make water. I use this
after in the 13 gallon tank. For washing and sometimes dog water.
fresh water lake (no brainer) unlimited supply. If the lake is a little dirty
pump the water to your tank using a bilge pump through a water filter.
get a cheap bilge pump add long wire and 12 volt plug. drop into the lake and you have a cold water shower, pump to pump water to your tank a cheap wash down. All kinds of uses.
oh and by the way water in the ice chest if left in there and ice added
your cooler will be near freezing and the cold drinks are very cold. The beer will be so cold it goes down like sweet melted butter. to bad I have to go to work now it sounds good.
