Damaged Jellcoat
Posted: Mon Jun 14, 2004 8:55 am
by ysayin
Hi,
Because of an engine problem I damaged the jellcoat and/or the paint at head above the waterline. Thanks god no cracks.
I need urgent help about what I can do to repair it. It is as bis as a golf ball and I can see the fiberglass.
Would it be enough if I use something like they use on the cars or sholud I buy a jellcoat kit?
I stared feeling better already, it is good to share anyway...
Yalcin
Posted: Mon Jun 14, 2004 10:17 am
by Duane Dunn, Allegro
I have filled many cracks and holes with white MarineTex. The first time out with the used boat I discovered the bow support blocks were too far apart and the boat hit the crossbar removing about 18" of gel coat along the keel (I have since put in a roller). To repair it I used MarineTex and it worked great. It's easy to use, matches quite well. It's a two part epoxy compound. Once you have the area filled, wet your finger and smooth the surface. It will not stick to the wet finger and you can get a perfect smooth surface without the need for any sanding. Most marine stores sell it or you can get it online.
Posted: Mon Jun 14, 2004 12:20 pm
by mark,97x
thanks i needed that ,,,,,,info also
Gel Paste
Posted: Mon Jun 14, 2004 12:45 pm
by BobCardz
Gel paste can be colored and applied fairly easily as well. A quick fix in one day or you can work it for a few days and make the chip blend so you cant tell it was there. It's really more about patience than skill. Unless you have a mold section don't expect perfection in one day. There are several books on the matter. After a while you stop fearing the chip.. even in the diamond non-skid.
Thanks
Posted: Tue Jun 15, 2004 12:47 am
by ysayin
Thanks for your help, I never care about anything about my car. I repair such a damage may be 2 years later but when it comes to my boat since I don't know the risk I'm taking about doing something wrong I don't feel comfortable.
Yalcin
