Winch Overwrapping?
Posted: Sat Aug 25, 2007 2:39 pm
While sailing with the jib, I have problems with the jib sheet wrapping over itself on the winch. I believe this happens mainly while sheeting in with a few wraps on the winch.
This is probably an old subject, I did attempt to search for old posts but have decide to take the easy way out.
Do others have this problem, I am trying to figure out if it is an equipment problem or an issue with my technique. The winches are stock 2003 stuff. I usually wind the sheet clockwise around the winch a few times, then either sheet it in or ease it, and pull it into the jam cleat. This over run problem is killing me.
could I get some advice?
thanks,
Kevin
thanks,
Kevin
