prop is spinning in neutral
- ALX357
'Put the water earmuffs on my boat's motor in the back-yard today, and ran it for about 10 minutes ... started well and ran smooth, but as usual, the prop is spinning even though it is in neutral. Not with any force, as I can grab the hub with my hand and easily stop it, but it starts spinning again when released. I am thinking this is normal, but would like confirmation and a mechanical explanation, if anyone has one.
Thick oil
I think this effect is just because the gear oil is so thick - even though the gears are not actually engaged, there is not a lot of clearance between them and the drive gear "drags" the oil which in turn "drags" the driven gear.
I suspect the effect might go away if the gear oil was hot.
- Andy
- Andy
- nchogberg
- Location: Boca Raton, Fl '01 26x, www.freewebs.com/nchogberg
- ALX357
Thank you for the concern, consideration for safety. Probably good advice for most people.
As for me, motor running in neutral, hand was on the hub of the prop, not the blades, boat is firmly on the trailer, not going to jump at me.
This kind of thing may scare some people, but I am a carpenter, use power tools every day, run lumber thru a table saw, my hands a few inches from the powered blade, use a skillsaw, same thing. etc.
It is hand and eye coordination. At least it is just me trusting myself. Most of us also have to trust others - drivers, which is more scary by far.
Ever have to drive on a two-lane highway at night ? Of course we all have .... Two strangers, trusting each other while passing within three feet of each other piloting lethal mass weapons going opposite ways, at a combined speed of maybe 130 mph. And the next car too, maybe for hours on end. Hope nobody sneezes.
