Pete wrote:I guess the biggest thing I am still up in the air about is the motor. I have been looking at everything in the 50-90 hp range. To me weight is the biggest downfall of larger motors. Am I over worried about the extra 100-150 lbs a 75 or 90 hp motor would add. Will I loose to much sailing performance by adding the extra weight of the bigger motor.
E-Tec 40, 50, 60 = 240LBS
Honda 75 = 365 Lbs
Yahama 50, 60 = 237 Lbs
Yahama 75, 90 = 369 Lbs
Pete
Performance under power is more important to me. If I wanted a great performing SAIL boat, the Mac is probably not the best choice. The flat bottom (shallow draft), high speed under power is what appeals to me. The fact that if I'm 20 miles from port and the weather gets hairy, I can get back quickly is attractive. Sailing is fun because it's slow and relaxing, I'm not in a rush to get anywhere. I could take a small hit on sail performance.
However, if the extra weight means that I have to limit the number of people on board (specifically in the cockpit), that might be a problem.
I'd be more concerned with reliablity. What motors have the best reliablity ratings?
