Need to be taken under a experienced captains wing
eric3a
Post by eric3a »
johnnyonspot
Post by johnnyonspot »
eric3a wrote:Ouch!
Sounds like design fault to me then.
Failure of the axis and/or lifting cable should NOT result in loosing the whole keel, but should result in the keel being permanently in a low position.
I've seen a number of such designs where the failure mode is board all down.
Clearly needs to be inspected regularly then.
Eric
I agree that if only the cable breaks you will be okay, as one should be able to use a line run underneath the boat athwartships from the bow and slowly drag it back, as if you were keel-hauling someone, until it catches the swing keel then use the line to pull the swing keel up into the trunk. The winches would be needed to help but it should be doable.
I was thinking more alone the lines of a keel pivot bolt failure, which would cause the keel to drop away. I doubt very much the keel cable would arrest the sinking of the keel once the bolt fails.
sailinglady05
Have restored my 1978 Venture 23'
Post by sailinglady05 »
Bea,
I have just completed an 8 month restoration on my boat from damage sustained in a trailering accident. We may have the same boat. I know her pretty well stem to stern now. I am is the process of replacing the keel pivot bolt this week, then she will be back in the water for the first time since Katrina in Louisiana :D . Blue Water Yachts has Macgregor parts, and can sometimes answer questions that you may have, 1-800-688-8626. Becky
James V
Post by James V »
I can give you some instructions, Just make it down to anywhere in the Abaco's Bahams and I will contact you.
Correct spelling error
Trouts Dream
Post by Trouts Dream »
James V wrote:I can give you some instructions, Just make it down to anywhere in the Abaco's Bahams and I will meat you.
I hope that's a spelling mistake. (meat?) :o :D
:D
Why is it my neighbors lingerie model always gets help docking her boat at the marina?? Do I need that blue hull after all??
bastonjock
Post by bastonjock »
Catigale wrote::D
no stephen you dont need the blue hull,just some lingerie,make sure that the colour matches your eyes :D
James V
Post by James V »
Trouts Dream, Correct the spelling error.
