Centerboard Pin
Snow Goose
Centerboard Pin
Post by Snow Goose »
Does anyone know what material is in the centerboard pin? Mine is very pitted and I would like to replace it.
Thanks
Don T
Post by Don T »
Hello,
Pitted? It should be made of stainless.
LOUIS B HOLUB
Post by LOUIS B HOLUB »
I did a bottom job recently, and my pin is stainless. It was shiney, like new, & clean. I had to insert a 1/2" PVC (schedule 40) pipe through the Centerboard because it was rounded out somewhat. The Pin fits perfectly thru the PVC, and works well with this combination.
But, I thought all CB pins were stainless.
:macx:
Snow Goose
It looks like a stainless sheath on a steel pin? The stainless is worn in places, I assume from the movement of the centerboard?
TrueNorth
Post by TrueNorth »
LOUIS B HOLUB wrote:I did a bottom job recently, and my pin is stainless. It was shiney, like new, & clean. I had to insert a 1/2" PVC (schedule 40) pipe through the Centerboard because it was rounded out somewhat. The Pin fits perfectly thru the PVC, and works well with this combination.
:macx:
Louis,
Can you explain how you inserted the 1/2" PVC pipe over your centerboard pin. How did you access pin and any problems during repair?
Thanks.
opie
Post by opie »
CB REPAIR
Here is a link to a comment I made in 2007, now in the archives. Pitting will not hurt anything, as you can see mine is pitted as well. The pin only touches the fulcrum holder in two small spots.
