What are the chances Roger is recycling his foam no longer needed foam packaging rather than sending it to the land fill or recycle collector??Frank C wrote:I wouldn't want to glue all those blocks together. Opening the flotation compartments is frequently the only logical approach to repairing deck fittings, or adding new ones. I want to be able to remove Roger's foam, when I so choose.J.Teixeira wrote:. . . Even bi injecting foam between the already existing blocks because that process will glue them together and to the hull becoming a single strong block.
And with a long thin pipe I am sure that the entire area can be filed…
More ideas, experience or suggestions?
I mean you have to hand it to him, he is cleaver, and he has engineered a reasonabley strong light weight boat. . .heavy doesn't make it stronger . . .
