26M Dock Height.
dxg68
26M Dock Height.
Post by dxg68 »
Hi, I am buying a Macgregor 26M next year. I am going to keep it in a slip for the summer. I am going to build a new dock. How high should the dock be from the water surface to comfortably go in and out from the boat? Thanks for your advice.
Terry
Re: 26M Dock Height.
Post by Terry »
I pulled into a visitor slip at one marina where I had to climb up from my boat onto the dock as the dock was higher than my cockpit combing! :D
Since you are going to build it, perhaps a height halfway up from the waterline to the cockpit combing might be sufficient enough to step over, or maybe as high as the rub rail so that you can step onto the boat anywhere along the deck from your dock. Must be nice to be able to plan a custom built dock. 8)
dxg68
Post by dxg68 »
Terry,
I will not have the boat until next year. What is the distance in inches from the waterline the cockpit? Thank you.
Derrick
Post by Derrick »
My M is in the back yard and I just measured for you.
Waterline to rub rail (at midpoint of cockpit) is 33".
Rub rail to top of cock pit coaming (at mid point of cockpit) is 14"
Waterline to rub rail (at mid point of bow) is 42"
If I were making a dock, I would make it so the rub rail can mate up against the dock to save the hull from scratches.
At our slip on Lake Michigan, the dock is a good step up (sometimes two, pending water levels) and we have a ladder to climb up on the dock for additional safety reasons (not the greatest). Good thing is the boat just goes up against two wood pilings and rub rail takes all the bumping. We have bumpers hanging down the pilings as additioanl protection. In two summers not one scratch on the hull yet.
dxg68
Post by dxg68 »
Derrick,
Thanks for a great advice!!!
Tony D-26X_SusieQ
Post by Tony D-26X_SusieQ »
Don't forget to take the tides into account. Depending on where you are they can make a big difference. I spent a few days at the Coast Guard station at Cape May, NJ and soon discovered that the dock I could step out on when I arrived was 20 feet above my deck just a few hours later. :x
pokerrick1
Sailboat: Venture 23
Post by pokerrick1 »
In which case a floating dock and stairs to the M work best.
Rick :) :macm:
