dclark wrote:I'm no scientist or anything and maybe that's the problem, but I don't think I understand...
Are you saying hydrogen got trapped in the inverter (it looks lower than the battery in the picture)? Then it stayed there thru all that checking and trailering, then the inverter created an internal spark which caused some kind of a mini hindenberg thing?
Thats the only thing I could come up with..I would only get the pop after the battery was charged either by charger or motor.
No charging..no pop.
I even left the cover off for a while before turning it on..to ensure it was clear. (I DID think about this before this happened)
Other than that I have no clue why it died.
I did replace it. I'll see if it happens again.
Unless the unit was just a faulty unit, did not like trailering, or whatever...
Only 2 theories I could figure out. The installation looks OK to me. Do not think it was an installation issue.
I will take other theories...
FWIW ...this is the Costco unit for $70 (later reduced to $29, bought 2 more).
