Thanks Matt,
O.K. I now know that my weight concerns are not without foundation with my new boat. One thing known.
My motor is a 50 Hp Honda 2003. My boat is a Mac 26 M 2003, which means the galley and the fresh water tank are on the same side as the toilet closet, in front of the mirror which is «tribord» in French and (please somebody clarify) starbord (?????) in English.
I do not want to carry fresh water in a tank for the toilet. I believe a throughhull can be done if one is careful, prudent, takes advice, etc.
Here is something I am wondering about: is it possible to keep a ballast tank empty while the boat is sitting in the water for more than a week...I feel you would need NASA valves to perform that..... The level of the throughull could be influenced by 4 inches based on that information.
The throughull would have to be located very low, if the toilet would have to work on an empty ballast. Locating it in the toilet cabinet would not work, since the ballast level is at the level of a possible throuhull.
I am almost sure the throughull would have to be located AT LEAST as far aft as the lower side of the step, maybe farther aft.....still not fixed on that...
For the holding's tank, if the weight is located on the left or «babord» port (?????) side, it could only help, shouldn't it ??????
Digging Mike (not worried, used to these unknown things and likes them somewhat...)
Thanks
